Updated on 2025-09-23 GMT+08:00
Setting Notifications for Repositories and MRs
CodeArts Repo can push repository and merge request notifications by email or WeCom. You can enable the notifications as required.
  • Configure the MR notification of the repository by referring to this section.
Requirement
Members in the repository can view this page. Only roles with the set permission in CodeArts Repo can configure the notification settings of the repository. For details, see Configuring Repo-Level Permissions.
Configuring Email Notifications
Go to the homepage of the repository to be configured. Choose Settings > General Settings > Notifications from the navigation bar. Set the notification type to Email. For details about the email notification parameters, see the following table.
Table 1 Parameters for email notifications
Repository
Optional. Set the email notification you want to receive. Four options are available. By default, Freeze Repo and Close Repo are selected and cannot be changed. If a repo is frozen or closed, an email will be sent to the repo owner and project administrator. The other two options are as follows, and you can select when to receive email notifications:
  • Delete Repo: When a member deletes the repository.
  • Capacity Warning: When the capacity usage exceeds the threshold. You can select 60%, 80%, or 90% from the drop-down list.
Merge Request
Optional. You can select the following options as needed.
  • Open: When a merge request is created or re-created, an email will be sent to the selected roles. By default, the following roles are selected: Scorer, Approver, Reviewer, and Merger.
  • Update: When the code of the branch associated with the merge request is updated, an update email is pushed. The following roles are selected by default: Scorer, Approver, and Reviewer.
  • Merge: An email will be pushed when a merge request is committed. The MR creator is selected by default. You can also select Merger.
  • Review: An email will be sent to notify the merge request review. The MR creator is selected by default.
  • Approve: An email will be sent to notify the merge request approval. The MR creator is selected by default.
  • Comment: The email of new review comments will be sent to the selected role. The MR creator is selected by default.
  • Resolve Comment: An email will be sent to the selected role to resolve the review comments. The MR creator is selected by default.
Configuring WeCom Notification Settings for the Repository
Table 2 Parameters for setting WeCom notifications
Webhook URL
Used to identify webhook address of the robot added to the CodeArts Repo member group with a maximum of 500 characters.
Repository
Optional. Select the following two options based on your need. By default, the following two options are selected. You can also select the email recipients.
Merge Request
  • Status Change Notifications are pushed through the WeCom bot when the MR is opened, updated, or merged. By default, the following options are selected: Open and Merge.
  • Review and Approval: You can select Review or Approve.
  • Review Comments: By default, Comment is selected. You can also select Resolved comment.
