Help Center/ CodeArts Repo/ User Guide/ Managing Member Permissions/ Configuring a Repository Group's Permissions
Updated on 2025-09-23 GMT+08:00
The repository group permission matrix can be modified only by the project administrator and the owners of repository groups at each layer.
Steps
Log in to the target repository group's page. In the navigation pane on the left, choose Settings > Security Management > Permissions.
  1. You can enable Use Project Permissions to use project-level permission configuration, which cannot be changed.
    You can also click to sync project permissions. After the synchronization, you can modify the permissions.
    You can also configure the permissions according to the following table. A indicates that the role has the permission by default and cannot be removed. B indicates that the role has the permission by default and can be removed. C indicates that the role can be assigned with the permission. D indicates that the role cannot be assigned with the permission.
    Table 1 Permissions of the repository group roles
    Role/Permission
    Permission
    Project Manager
    Product Manager
    Test Manager
    Operation Manager
    System Engineer
    Committer
    Developer
    Tester
    Participant
    Viewer
    Customized Role
    Repository Group
    Create
    B
    C
    C
    C
    B
    B
    B
    C
    C
    D
    C
    Delete
    B
    D
    D
    D
    D
    D
    D
    D
    D
    D
    C
    Setting
    B
    D
    D
    D
    D
    D
    D
    D
    D
    D
    C
    Repository
    Create
    B
    C
    C
    C
    B
    B
    B
    C
    C
    D
    C
    Fork
    B
    D
    D
    D
    D
    D
    D
    D
    D
    D
    C
    Delete
    B
    C
    C
    C
    B
    B
    B
    C
    C
    D
    C
    Setting
    B
    D
    D
    D
    D
    D
    D
    D
    D
    D
    C
    Code
    Commit
    B
    C
    C
    C
    A
    A
    A
    C
    C
    D
    C
    Download
    B
    C
    C
    C
    A
    A
    A
    C
    C
    D
    C
    Member
    Add
    B
    D
    D
    D
    D
    D
    D
    D
    D
    D
    D
    Edit
    B
    D
    D
    D
    D
    D
    D
    D
    D
    D
    D
    Delete
    B
    D
    D
    D
    D
    D
    D
    D
    D
    D
    D
    Branch
    Create
    B
    C
    C
    C
    B
    B
    B
    C
    C
    D
    C
    Delete
    B
    C
    C
    C
    B
    B
    B
    C
    C
    D
    C
    Tag
    Create
    B
    C
    C
    C
    B
    B
    B
    C
    C
    D
    C
    Delete
    B
    C
    C
    C
    C
    C
    C
    C
    C
    D
    C
    MR
    Create
    B
    C
    C
    C
    B
    B
    B
    C
    C
    D
    C
    Edit
    B
    D
    D
    D
    C
    B
    C
    D
    D
    D
    C
    Comment
    B
    C
    C
    C
    B
    B
    B
    C
    C
    C
    C
    Review
    B
    D
    D
    D
    B
    B
    B
    D
    D
    C
    C
    Approve
    B
    D
    D
    D
    C
    B
    C
    D
    D
    D
    C
    Merge
    B
    D
    D
    D
    C
    B
    C
    D
    D
    D
    C
    Close
    B
    D
    D
    D
    C
    B
    C
    D
    D
    D
    C
    Re-open
    B
    D
    D
    D
    C
    B
    C
    D
    D
    D
    C
