Updated on 2025-09-23 GMT+08:00
Obtaining an Access Token from Coding
Requirement
You already have a Coding account.
Configuring an Access Token
  1. Log in to Coding, click the profile picture in the lower left corner, choose Personal Account Settings, and click Access Tokens. On the current page, click Create Token in the upper right corner.
  2. Enter Token Description and set Expiration time, as shown in the following figure. Configure the repository permission, which can be set to ReadWrite.
    Figure 1 Configuring repository permissions
  3. Configure IP Whitelist as needed. If you do not need to configure it, click Confirm. Then, perform identity authentication as prompted.
  4. Click to copy and save the current access token.
