Updated on 2026-09-30 GMT+08:00
Migrating a Coding Repository
Configure the personal access token by referring to Obtaining an Access Token from Coding.
Steps
  1. Go to the CodeArts Repo homepage, click New Repository, and select an existing project from the Project drop-down list box or create a project.
  2. Set the repository type to Imported, import from Coding, and select By personal access token for Authorization. If an error message indicating authorization failure is displayed, it means your access token is incorrect or invalid. In this case, reconfigure your access token in Coding by referring to Obtaining an Access Token from Coding.
  3. Select repositories to be imported and click Next. Enter Basic Information and set Repo Sync Settings by referring to Enter Basic Information for Imported Repositories and Table 1 Parameters for syncing repo settings.
  4. Click OK. The repository list page of the project is displayed. If the following figure is displayed, the Coding repository is successfully imported.
    Figure 1 Coding repository successfully imported
