Configuring Basic Information for a New Repository
Parameter |
Description |
Path |
Optional. The default value is /, indicating that the repository does not belong to any repo group path. You can also select an existing repo group path from the drop-down list. |
Repository Name |
Name of the repo to be imported. Start with a letter, digit, or underscore (_), and use letters, digits, hyphens (-), underscores (_), and periods (.). Do not end with .git, .atom, or periods (.). |
Visibility |
Optional. Indicates the visible scope of the source repo. The options are as follows:
Scheduled Sync |
Optional. If you select this option, the imported repo is an image repository, which cannot commit code and can only be synced from the source repository periodically. The code is automatically refreshed every 24 hours. The refreshed content is the content of the source repository 24 hours ago. If no endpoint is used to import the repository, you do not need to configure Scheduled Sync. |
