Migrating a Gitee Repository
- Configure the personal access token by referring to Obtaining an Access Token from Gitee.
Steps
- Go to the CodeArts Repo homepage, click New Repository, and select an existing project from the Project drop-down list box or create a project.
- Set Repository Type to Imported, Import From to Gitee, and Authorization to By personal access token. Enter the token and click Next.
If an error message indicating authorization failure is displayed, it means your access token is incorrect or invalid. In this case, reconfigure your access token in Gitee by referring to Obtaining an Access Token from Gitee.
- Select repositories to be imported and click Next. Enter Basic Information and set Repo Sync Settings by referring to Enter Basic Information for Imported Repositories and Table 1 Parameters for syncing repo settings.
- Click OK. The repository list page of the project is displayed. If the following figure is displayed, the repository is being imported. Figure 1 Repository being imported
If the following figure is displayed, the Gitee repository is successfully imported.Figure 2 Gitee repository successfully imported
If the following figure is displayed, the Gitee repository fails to be imported.
Figure 3 Repository import failure
