Configuring Repository Synchronization
Overview
CodeArts Repo allows you to sync the settings of the current repository to other repositories as you want.
This function is used for a forked repository because the settings of the original repository are not automatically copied during forking.
Item |
Description |
Permission constraint |
If you have the set permission on the target repository, you can configure the synchronization settings. For details about how to configure permissions, see Configuring Repo-Level Permissions. |
Function constraint |
This function supports cross-project synchronization but does not support cross-region synchronization. |
Configuring Synchronization Between Repos
If you have enabled Inherit from project, you cannot synch settings.
Only members with the Set permission can perform this operation. Members in the repo can view this page.
Go to the repo homepage and choose . Click Add Repository. In the dialog box that is displayed, select the target repository.
Helpful Links
Common failure causes:
- Failed to sync Commit Rules: No commit rules are set for the source repository.
- Failed to sync Protected Branches: The branch names of the source repository and target repository are different.
