Help Center/ CodeArts Repo/ User Guide/ Creating a Repository/ Creating a Repository Using a Template
Updated on 2025-09-23 GMT+08:00
CodeArts Repo provides various repository templates for you to create repositories from. Before creating a repository, refer to Constraints and Procedures. You can view the official templates supported by CodeArts Repo in Official Repository Templates.
Before creating a repository using a template, check whether the prerequisites are met by referring to Prerequisites for Creating a Repository.
Procedures
  1. Access the CodeArts Repo homepage as shown in the following figure.
    • Click New Repository, and select an existing project from the Project drop-down list box or create a project.
  2. Set Repository Type to Template.
    Custom templates can be set on the repository settings page. You can set official templates as custom ones.. After selecting a template, set parameters based on the table.
  3. Click OK. The Code page of the new repository is displayed. As shown in the following figure, the repository Test_0707 is successfully created.
    Figure 1 Repository Test_0707
Table 1 Repository templates
Key Provider
Java Maven Demo
It uses the Maven template for building. Programming language: Java. Build tools: Maven 3.5.3 and JDK 1.8.
Java Ant Demo
It uses the Ant template for building. Programming language: Java. Build tools: Ant 1.10.3 and JDK 1.8.
Android Gradle Demo
It uses the Gradle (for Android) template for building. Programming language: Java. Build tools: Gradle and JDK 1.8.
Cpp Demo
It uses the CMake template for building. Programming language: C/C++. Build tools: CMake 3.10.1 and GCC 5.5.0.
Windows Cpp Demo
It uses the MSBuild template for building. Programming language: C++. Build tool: MSBuild 15.0.
Groovy Grails Demo
It uses the Grails template for building. Programming language: Groovy. Build tools: Grails 2.5.0 and JDK 1.8.
Python2 Demo
It uses the SetupTool template for building. Programming language: Python. Build tool: Python 2.7.
Python3 Demo
It uses the SetupTool template for building. Programming language: Python. Build tool: Python 3.6.
C Codesoucery Demo
It uses the Gnu-arm template for building. Programming language: C. Build tool: gnuarm201405 image.
Cpp LiteOS Demo
It uses the Gnu-arm template for building. Programming language: C++. Build tool: gnuarm-7-2018-q2-update.
Node.js Webpack Demo
It uses the NPM template for building. Programming language: Node.js. Build tool: Node.js-8.11.2.
C# Demo
It uses the MSBuild template for building. Programming language: C#. Build tools: MSBuild15-dotnetframework 4.7.2.
Java Web Demo
This sample repository is used to demonstrate how to use CodeArts to build and deploy via pipelines on cloud.
Go web Demo
It uses the Hello World applet based on the Go language. Programming language: Go. Build tool: Go-1.10.3.
Java War demo
It uses the Hello World applet complied based on the Maven language and generates a .war package after using Maven for building. Programming language: Java. Build tools: Maven 3.5.3 and JDK 1.8.
Phoenix Mall
An example of an e-commerce website that helps developers quickly learn about CodeArts features and solve software development, testing, and deployment problems during microservice use.
