- What's New
- Function Overview
- Product Bulletin
- Getting Started
User Guide
- Process of CodeArts Repo
- Purchasing CodeArts
- Accessing CodeArts Repo Homepage
- Environment and Personal Settings
- Migrating Code and Syncing a Repository
- Creating a Repository
- Viewing Activities
- Viewing Repository Statistics
- Configuring Repository Settings
- Hierarchical Repository Management
- Configuring a Repository
- Managing Repo Member Permissions
- Cloning or Downloading Code Repo to a Local PC
- Uploading Code Files to CodeArts Repo
- Developing a Workflow
- Creating and Configuring a CodeArts Project
- Committing Code to CodeArts Repo and Creating a Merge Request
- Managing Merge Requests
- Managing Code Files
- Security Management
- Best Practices
- Authentication
- Member Permissions
Uploading and Downloading Code
- "Error: Deny by project hooks setting 'default': message of commit" Is Reported When Code Repository Is Pushed from the Local Host to CodeArts Repo
- Pushing Binary Files to CodeArts Repo Failed
- Error "'origin' does not appear to be a git repository..." Is Reported When the Git Push Command Is Executed
- Error "The requested URL returned error: 401" Is Reported When HTTPS Is Used to Clone Code in CentOS
- Error "Merge branch 'master' of https://test.com Please Enter a commit" Is Reported When Pulling Code Using the Git Pull Command
- Message "fatal: refusing to merge unrelated histories" Is Displayed
- How Do I Prevent Files Containing Secrets from Being Pushed to CodeArts Repo?
- Migrating Repositories
- Merge Request
- Fork Sync
- Repository Capacity
- FAQs
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- SSH Key
Repository
- Obtaining Files in a Branch Directory
- Obtaining Repository Statistics
- Obtaining Image Files of a Specific Branch in a Repository
- Modifying the Status of a Repository Referenced by a Pipeline
- Checking Whether a User Has the Repository Administrator Permission
- Setting a Repository to Public or Private
- Obtaining the Content of a Specified File in a Specified Branch of a Repository
- Obtaining a Public Template List
- Obtaining a Repository Short ID to Generate the Details Page URL
- Querying a Commit of a Branch by Repository or Repository Group Name
- Querying Branches of a Specified Repository
- Querying a Commit of a Repository Branch by the Repository ID
- Adding a Deploy Key
- Deleting a Deploy Key
- Obtaining the Last Commit Statistics of a Repository
- Repository Statistics
- Deleting a Repository
- Viewing a Repository Creation Status
- Querying the Tag List of a Repository
- Adding a Tag
- Querying Details About a Repository
- Obtaining the number of committed code lines
- Downloading a Repository
- Creating a Protected Branch
- Deleting a Protected Branch
- Deleting Protected Branches in Batches
- Creating a Protected Tag
- Deleting a Protected Tag
- Obtaining a Repository Branch List
- Obtaining the MR List of a Repository
- Obtaining MR Details of a Repository
- Obtaining the Repository IP Address Whitelist
- Adding the Repository IP Address Whitelist
- Modifying the Repository IP Address Whitelist
- Deleting the Repository IP Address Whitelist
- Obtaining the Changes of an MR
- Associating a Repository with a Member Group
- Locking a Repository Based on the Repository Short ID
- Unlocking a Repository Based on the Repository Short ID
- Approving an MR
- Obtaining Associated Work Item Information
- Obtaining Reviewer Information Based on the Repo Short ID and Merge Request Short ID
- Obtaining the List of Changed Files
- Tenant
- Group
- Project (V2)
- RepoMember
- Commit
- File
- User
- Webhook
- Project
- Repository Management (V2)
- Review
- Application Examples
- Appendix
- Videos
On this page
Show all
Help Center/
CodeArts Repo/
User Guide/
Migrating Code and Syncing a Repository/
Syncing Repo Settings
Parameter |
Description |
Branch |
Mandatory. The options are as follows:
Schedule |
Optional.
NOTICE:
If you select this option, the imported image repository cannot commit code and can only be synced from the source repository periodically. The code is automatically refreshed every 24 hours. The refreshed content is the content of the source repository 24 hours ago. |
Parent topic: Migrating Code and Syncing a Repository
