Verifying the Import Permission
- Verifying permissions through service endpoints
- Link name. Mandatory. Enter a name with a maximum of 256 characters.
- Git repository URL. Mandatory. Enter the URL of the source repository to be imported.
- Username. This parameter is mandatory when the source repository is private. Username for cloning HTTPS code, for example, GitHub login name.
- Password or access token. This parameter is mandatory when the source repository is private.
Password or access token for cloning HTTPS code. For example, to obtain an access token from GitHub, see Obtaining an Access Token.
- Verifying permissions through username and password
Select By username and password and set the parameters by referring to the following table.
Table 1 Verifying permissions through username and password Parameter
Username
Password/Access token
