E2E Settings
Item |
Description |
Function constraint |
The repositories of Kanban projects do not support E2E settings. |
Permission constraint |
You must have the set permission on repositories to configure E2E settings. For details, see Configuring Repo-Level Permissions. |
Configuring E2E Settings
If you select Inherit from project, the settings of the project are automatically inherited and cannot be modified.
If you do not inherit the project-level configuration, go to the repository homepage, choose Settings > Service Integration > E2E Settings, and configure the E2E settings as instructed in E2E Settings.
