Updated on 2025-09-23 GMT+08:00
Migrating a Git Repository Using a URL
  • The repository domain must be connected to the service node.
  • Currently, Git supports the following external import sources: bitbucket.org, code.aliyun.com, coding.net, git.qcloud.com, gitee.com, github.com, gitlab.com, visualstudio.com and xiaolvyun.baidu.com.
  • After a code repo is created, only the creator can access the repo. Other project members need to be manually added to the repo and assigned with permissions. Therefore, you need to manually add members to the repository and configure access permissions for the new members by referring to Configuring Repo-Level Permissions.
Steps
  1. Go to the CodeArts Repo homepage, click New Repository, and select an existing project from the Project drop-down list box or create a project.
  2. Set repo type to Import, and import from Git URL. For details about how to set parameters, see Table 1.
    Table 1 Parameters for obtaining authorization
    Source Repository URL
    Specifies the repo path to be imported. The source repository path must start with http:// or https:// and end with .git.
    Verification to Access Source Repo
    There are two cases:
    • If the imported source repository is open to all visitors, select Not needed.
    • If the imported source repository is private, select Needed. Currently, two authentication modes are supported: By service endpoint and By username and password. For details about how to set parameters, see Verifying the Import Permission.
  3. Click Next. On the Basic Information page, set parameters by referring to the parameter table.
  4. Set the parameters for syncing a repo by referring to table 1. After the parameters are set, the Code page for creating the repo is displayed.
Helpful Links
  • If the repo file is too large or the network quality is poor, it may take more than 30 minutes to import the repo file. If the import times out, you are advised to use the client clone/push to handle the problem. For details, see Importing an External Repository Timed Out
  • On the repository list page, if the new repository name is in gray with a red exclamation mark next to it, the repository fails to be imported. The possible cause is that the username, password, or access token is incorrect. You can delete the repository and import the external repository again according to Migrating a Git Repository Using a URL.
