Using a Browser to Download Code Package to a Local PC
Item |
Description |
Function constraint |
The size of the file to be downloaded must be less than 500 MB. |
Permission constraints |
Downloading a Code Package
CodeArts Repo supports both cloning code repositories and packaging repository code for local download. The downloadable package contains the content of a specified branch.
- Access CodeArts Repo homepage.
- Go to the homepage of the repository to be cloned, switch to the branch to be downloaded, and click Clone/Download.
- In the dialog box that is displayed, click the required code package type to download it.
If the download takes more than 5 minutes, use the git command to download the file.
