Forking a Repository
Application Scenarios
The fork function can be used in large-scale projects with multiple sub-projects.
You can fork a repository (an image) based on a repository and merge the CRs in the image to the source repository.
When there is no merge, the modification of both the image repository and source repository will not affect each other.
As shown in the following figure, the complex development process occurs only in the image repository and does not affect the project version repo (source repo). Only the confirmed new features can be merged back to the project version repo. Therefore, fork is a team collaboration mode.
Differences Between Forking a Repository and Importing an External Repository
Both forking or importing a repo is a process of replication. The main difference lies in the association between the source repository and the copied repository. The details are as follows:
- Fork
- Forks are used to copy repositories on CodeArts Repo.
- A fork generates a repository copy based on the current version of the source repository. You can apply for merging changes made on the fork to the source repository (cross-repository branch merge), but you cannot pull updates from the resource repository to the fork.
- Import
- You can import repositories of other version management platforms (mainly Git- and SVN-based hosting platforms) or your own repository to CodeArts Repo.
- An import also generates a repository copy based on the current version of the source repository. The difference is that you can pull the default branch of the source repository to the repository copy at any time to obtain the latest version, but you cannot apply for merging changes made on the repository copy to the source repository.
Before forking a repository, you must have the necessary permissions; see Configuring Repo-Level Permissions.
Steps
- Access the repository list page. Click a repository name to go to the target repository.
- Click Fork in the upper right corner. In the displayed Fork Repository window, set parameters by referring to the following table.
Table 1 Fork repository parameters Parameter
Project
Target project of the new repo. You can select a project name you have already joined from the drop-down list.
Path
Optional. Target repo group path of the new repo. You can select a repo group path from the drop-down list.
Repository
Start with a letter, digit, or underscore (_). You can use letters, digits, hyphens (-), underscores (_), and periods (.). Do not end with .git, .atom, or periods (.). The repository path (including the repository group name and repository name) cannot exceed 256 characters.
Visibility
Indicates the visible scope of the source repo. The options are as follows:
- Private: Only members of this repository can access it and commit code.
- Public: The value can be For project members, For tenant members, or For all guests.
Synchronize commit rules of the source repository
Optional. Indicates whether to synchronize the commit rules of the source repo. This option is selected by default, which means the source repo commit rules are synchronized.
You can choose Settings > Policy Settings > Commit Rules to view the rule settings of the source repo and determine whether to select it.
- Click OK to fork the repository. As shown in the following figure, after the fork is successful, the repository (group) page of the target project is automatically displayed, and Test is the forked repository.
Checking the Fork Status of the Current Repo
- Click the source repository name.
- Click the number after Fork in the upper right corner of the page to view the list of forked repositories, as shown in the following figure. The current source repo is forked only once. Click the name in the Fork repository name column to go to the Code page of the forked repo.
Merging Changes of a Fork to the Source Repository
- Click the name of the forked repository.
- Click the Merge Requests tab.
- Click Create MR. On the Create MR page that is displayed, select a source branch and target branch to be merged. Set Title and Description, and click Create MR.
Set the change topic to test. To copy the subject name, click
. To disassociate the subject from the request, click
.Note that a change topic:- Cannot use full-width or half-width quotation marks and cannot exceed 50 characters.
- Can be used for multiple merge requests. To do so, enter the same change topic ("test" in this example) for the merge requests when you are creating them.
Cross-repository merge requests belong to the source repository and can be viewed only on the Merge Requests page of the source repository. These merge requests cannot be viewed in the forked repository (that initiates these merge requests). Therefore, the reviewer, scorer, approver, and merger must be members of the source repository.
