- What's New
- Function Overview
- Product Bulletin
- Getting Started
User Guide
- Process of CodeArts Repo
- Purchasing CodeArts
- Accessing CodeArts Repo Homepage
- Environment and Personal Settings
- Migrating Code and Syncing a Repository
- Creating a Repository
- Viewing Activities
- Viewing Repository Statistics
- Configuring Repository Settings
- Hierarchical Repository Management
- Configuring a Repository
- Managing Repo Member Permissions
- Cloning or Downloading Code Repo to a Local PC
- Uploading Code Files to CodeArts Repo
- Developing a Workflow
- Creating and Configuring a CodeArts Project
- Committing Code to CodeArts Repo and Creating a Merge Request
- Managing Merge Requests
- Managing Code Files
- Security Management
- Best Practices
- Authentication
- Member Permissions
Uploading and Downloading Code
- "Error: Deny by project hooks setting 'default': message of commit" Is Reported When Code Repository Is Pushed from the Local Host to CodeArts Repo
- Pushing Binary Files to CodeArts Repo Failed
- Error "'origin' does not appear to be a git repository..." Is Reported When the Git Push Command Is Executed
- Error "The requested URL returned error: 401" Is Reported When HTTPS Is Used to Clone Code in CentOS
- Error "Merge branch 'master' of https://test.com Please Enter a commit" Is Reported When Pulling Code Using the Git Pull Command
- Message "fatal: refusing to merge unrelated histories" Is Displayed
- How Do I Prevent Files Containing Secrets from Being Pushed to CodeArts Repo?
- Migrating Repositories
- Merge Request
- Fork Sync
- Repository Capacity
- FAQs
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- SSH Key
Repository
- Obtaining Files in a Branch Directory
- Obtaining Repository Statistics
- Obtaining Image Files of a Specific Branch in a Repository
- Modifying the Status of a Repository Referenced by a Pipeline
- Checking Whether a User Has the Repository Administrator Permission
- Setting a Repository to Public or Private
- Obtaining the Content of a Specified File in a Specified Branch of a Repository
- Obtaining a Public Template List
- Obtaining a Repository Short ID to Generate the Details Page URL
- Querying a Commit of a Branch by Repository or Repository Group Name
- Querying Branches of a Specified Repository
- Querying a Commit of a Repository Branch by the Repository ID
- Adding a Deploy Key
- Deleting a Deploy Key
- Obtaining the Last Commit Statistics of a Repository
- Repository Statistics
- Deleting a Repository
- Viewing a Repository Creation Status
- Querying the Tag List of a Repository
- Adding a Tag
- Querying Details About a Repository
- Obtaining the number of committed code lines
- Downloading a Repository
- Creating a Protected Branch
- Deleting a Protected Branch
- Deleting Protected Branches in Batches
- Creating a Protected Tag
- Deleting a Protected Tag
- Obtaining a Repository Branch List
- Obtaining the MR List of a Repository
- Obtaining MR Details of a Repository
- Obtaining the Repository IP Address Whitelist
- Adding the Repository IP Address Whitelist
- Modifying the Repository IP Address Whitelist
- Deleting the Repository IP Address Whitelist
- Obtaining the Changes of an MR
- Associating a Repository with a Member Group
- Locking a Repository Based on the Repository Short ID
- Unlocking a Repository Based on the Repository Short ID
- Approving an MR
- Obtaining Associated Work Item Information
- Obtaining Reviewer Information Based on the Repo Short ID and Merge Request Short ID
- Obtaining the List of Changed Files
- Tenant
- Group
- Project (V2)
- RepoMember
- Commit
- File
- User
- Webhook
- Project
- Repository Management (V2)
- Review
- Application Examples
- Appendix
- Videos
Show all
Configuring an Access Token
Parameter |
Description |
Token Name |
Mandatory Custom name with a maximum of 200 characters. |
Description |
Optional. If the description is empty, -- is displayed in the list. Max. 200 characters. |
Permissions |
This parameter is selected by default and cannot be modified. Read/Write repo: Read from and write into repositories using HTTPS. |
Expired |
Mandatory Time when a token expires. 30 days after current date by default, including current date. For example, if a token is created on July 3, the default expiration date is 23:59:59 on August 2. The expiration date can be set to a maximum of one year and cannot be empty. |
After the parameters are set, the token is successfully generated. Copy and use it in the application or script.
- For security reasons, the token will not be displayed after this dialog box is closed. Keep the token safe. If you lose or forget it, generate a new one.
- A maximum of 20 tokens can be created for CodeArts Repo.
