Help Center/ CodeArts Repo/ User Guide/ Creating a Repository/ Creating Repos in Different Scenarios
Updated on 2025-07-24 GMT+08:00
You can create repositories based on your application scenarios. CodeArts Repo supports the following repository creation modes:
  • Create a custom repository. You can create a custom repository to suit your needs. If your local code repositories have not been integrated into any version control system, such as Git, you can migrate them to CodeArts Repo by creating a custom repository.
  • Create a repository using a template. You can quickly initialize a new repository and start version control by using the templates provided by CodeArts Repo.
  • Fork a repository. You can initiate new projects based on historical ones while preserving the repository structure of the latter.
Before creating a repository, check whether the prerequisites for creating a repository are met.
