Configuring an SSH Key
Introduction
An SSH key is an access credential in the SSH protocol. It establishes secure connections between the local computer and remote repositories.
You can configure an SSH key to ensure secure communication with CodeArts Repo. For details, see Procedure.
You can configure an SSH key by referring to Procedure or Configuring an SSH Key.
        Item  |
        Description  |
        Function constraint  |
        In an enterprise environment, developers often need to develop and debug code on multiple computers. To ensure all accounts can securely connect to services, they use SSH keys. In such scenario, if you have more than one computer, you need to configure an SSH key for each computer so that all accounts on the computer can be connected through the SSH key.  |
        Permission constraint  |
        If you have not completed real-name authentication, the Add SSH Key button is disabled.  |
You can configure an SSH key by referring to Configuring an SSH Key or the following steps.
- Run Git Bash to check whether an SSH key has been generated locally. Run the following command in Git Bash:
cat ~/.ssh/id_rsa.pub
 - Generate an SSH key. Run the following command to generate a key in Git Bash:
ssh-keygen -t rsa -b 4096 -C your_email@example.com
- -t rsa indicates that an RSA key is generated.
 - -b 4096 indicates the key length. (RSA keys of this length are more secure.)
 - -C your_email@example.com indicates that a comment is added to the generated public key file to help identify the purpose of the key pair.
Enter the command for generating a key and press Enter. The key is stored in ~/.ssh/id_rsa by default, and the corresponding public key file is ~/.ssh/id_rsa.pub.
 - Copy the SSH public key to the clipboard. Run the corresponding command based on your operating system.
- Windows:
clip < ~/.ssh/id_rsa.pub
 - Mac:
pbcopy < ~/.ssh/id_rsa.pub
 - Linux (xclip required):
xclip -sel clip < ~/.ssh/id_rsa.pub
 - Windows:
 - Log in to Repo and go to the code repository list page. Click the alias in the upper right corner and choose This Account Settings > Repo > SSH Keys. The SSH Keys page is displayed.
You can also click Set SSH Keys in the upper right corner of the code repository list page. The SSH Keys page is displayed.
 - In Key Name, enter a name for your new key. Paste the SSH public key copied in 3 to Key and click OK. The message "The key has been set successfully. Click Return immediately, automatically jump after 3s without operation" is displayed, indicating that the key is set successfully.
Related Document
- If Failed to add the key. Check whether the key is valid. is displayed, the entered key is invalid. If the key is manually copied from the local host, redundant spaces may have been copied or the copied key is incomplete. In this case, reconfigure the key by referring to 3.
 - When you configure an SSH key, the following message is displayed: SSH Key Already Exists, indicating that the key has already been added to an existing account. Solution: Generate a new SSH key locally by referring to the preceding steps and configure the generated key in CodeArts Repo.
 - CodeArts Repo provides an API to check whether private keys have the permission to pull code. For details, see Checking Whether a Private Key Has the Permission to Pull Code.
