Entering Basic Information for an Imported Repository
Parameter |
Description |
Path |
Optional. The default value is /, indicating that the repository does not belong to any repo group path. You can also select an existing repo group path from the drop-down list. |
Repository Name |
Mandatory. Name of the repo to be imported. Start with a letter, digit, or underscore (_), and use letters, digits, hyphens (-), underscores (_), and periods (.). Do not end with .git, .atom, or periods (.). |
Description |
Optional. Add a description for the repo. The description can contain a maximum of 2,000 characters. |
Initial Settings |
Optional. If you have enabled CodeArts Check, you are advised to select this option. After the repository is created, you can view the check task of the repository in the CodeArts Check task list. |
Visibility |
Optional. Indicates the visible scope of the source repo. The options are as follows:
