Updated on 2026-01-28 GMT+08:00
Installing and Configuring Git
Table 1 Constraints
Item
Security protocol compatibility
CodeArts Repo supports TLS 1.2 and TLS 1.3. If Git is the latest version, you can run the following command to specify the TLS version:
openssl s_client -connect test.com:443 -tls1_2
  • test.com is the domain name tls1_2 for Git upload and download in CodeArts Repo.
  • tls1_2 indicates TLS 1.2.
CodeArts Repo functions
GitHub Desktop is not supported in CodeArts Repo.
Install Git Client
Git is a version control system on which CodeArts Repo is built to provide an online service for hosting and managing your repositories.
For details about the clients supported by Repo and the installation guide link, see Table 2.
Table 2 Compatible Git clients
Client Name
OS
Official Installation Guide Link
Git client
Windows
Windows Git Client Installation Guide
Linux
Linux Git Client Installation Guide
Mac
Mac Git Client Installation Guide
TortoiseGit
Windows
Windows TortoiseGit Client Installation Guide
Windows Git client usernames can include letters, numbers, and common symbols. Characters with ASCII values less than or equal to 32, as well as ".", ",", ":", ";", "<", ">", """, "\", and "/" cannot be used at the beginning or end of the username.
For easier management, you can use your CodeArts Repo username.
Enter the following commands in Git Bash to configure the username and email address:
git config --global user.name your username
git config  --global user.email your_email_address
Helpful Links
For different Git client solutions, see compatible TLS protocol versions with CodeArts Repo.
