- Billing
- Getting Started
User Guide
HBase User Guide
HBase Cluster Management
- Overview
- Managing Clusters
- Preparing an ECS
- Using HBase
- HBase Cold and Hot Data Separation
- HBase Thrift Server
- HBase Security Channel Encryption
- HBase Batch Data Import
- HBase Monitoring Clusters
- Self-Healing from HBase Hotspotting
- Global Secondary Indexes
ClickHouse User Guide
ClickHouse Cluster Management
- Overview
- Managing ClickHouse Clusters
- Using ClickHouse
- Migrating ClickHouse Data
- ClickHouse User Management
- ClickHouse Role Management
- ClickHouse Slow Query Management
- Configuring Secure Channel Encryption for ClickHouse Clusters
- Application of ClickHouse Cold and Hot Data Separation
- ClickHouse Monitoring Clusters
- Permissions Management
- Audit Logs
- Cluster Log Management
HBase User Guide
Developer Guide
- HBase Application Development Guide
- ClickHouse Application Development Guide
General
- What Services Does a CloudTable Cluster Provide?
- Why Do I Choose CloudTable Service?
- How Do I Prepare for Creating a CloudTable HBase Cluster?
- What Should I Pay Attention to When Using CloudTable Service?
- What Compression Algorithms Are Supported by CloudTable HBase Clusters?
- Can I Stop CloudTable Service?
- Which Programming Languages Are Supported by HBase External APIs in CloudTable?
- How Do I Determine the Number of Faulty RegionServers?
- What Special Characters Does CloudTable HBase Support?
- What Can I Do If the Index Table Does Not Match the Data Table After CloudTable Data Is Deleted?
- What Should I Do If Concurrent Tasks Run Slowly When Python Accesses CloudTable Through Thrift?
- How do I view the TTL attribute of HBase shell?
- Why Are My Server Resources Released?
- How Do I Delete a Cluster?
- How Do I Stop Services and Release Resources?
Connection and Access
- How Do I Access a CloudTable Cluster?
- Can I Use SSH to Access Computing Nodes of CloudTable?
- Why Can't I Access HBase After the ZK Address Is Configured?
- Why Is the Error "Will not attempt to authenticate using SASL (unknown error)" Reported When Connecting to HBase?
- How Do I View the IP Address Corresponding to a Domain Name in a CloudTable Link?
- How Do I Access CloudTable from Other Cloud Services?
- Can I Configure the hbase-site.xml File?
- How Do I Query the Creation Time of a Table in CloudTable HBase?
Data Read/Write
- Is Raw Data Stored in CloudTable HBase?
- Why Can't I Write Data to HBase?
- What Is the Maximum Size of Data Written to the HBase Cluster?
- How Do I Check the Daily Incremental Data in HBase Tables?
- What Should I Do If an Error Is Reported When I Access the CloudTable HBase Cluster?
- How Do I Delete the Backup Table of the ZooKeeper Node in the ClickHouse Cluster?
- What Should I Do If a Database Missing Error Occurs When a Table Is Created in the ClickHouse Cluster?
- Billing FAQs
General
Show all
Querying Data with Indexes
Index-based Query
You can use SingleColumnValueFilter to query data in a table with indexes. When the query condition hits an index, the query speed is much faster than that of an ordinary table query.
Typical index query conditions are as follows:
- Query by multiple AND conditions
- When the columns used for a query contain at least the first indexed column, the query performance is optimized.
Assume that a composite index is created for C1, C2, and C3.
The index takes effect in the following queries:
Filter_Condition (IndexCol1) AND Filter_Condition (IndexCol2) AND Filter_Condition (IndexCol3) Filter_Condition (IndexCol1) AND Filter_Condition (IndexCol2) Filter_Condition (IndexCol1) AND Filter_Condition (IndexCol3) Filter_Condition (IndexCol1)
The index does not take effect in the following queries:
Filter_Condition (IndexCol2) AND Filter_Condition (IndexCol3) Filter_Condition (IndexCol2) Filter_Condition (IndexCol3)
- When you use "Index Column AND Non-Index Column" as a query condition, the index can improve query performance. If a non-index column hits a covering column, the query performance is optimal. If a non-index column needs to be frequently queried, you are advised to define it as a covering column. The following statement is an example:
Filter_Condition (IndexCol1) AND Filter_Condition (NonIndexCol1) Filter_Condition (IndexCol1) AND Filter_Condition (IndexCol2) AND Filter_Condition (NonIndexCol1)
- When multiple columns are used for query, you can specify a value range for only the last column in the composite index and set other columns to specified values.
Assume that a composite index is created for C1, C2, and C3. In a range query, only the value range of C3 can be set. The search criteria are "C1 = XXX, C2 = XXX, and C3 = Value range."
- Query by multiple OR conditions
- If only the first field in the index column is searched (range filtering is supported), indexing improves the query performance.
Filter_Condition (IndexCol1) OR Filter_Condition (IndexCol1) OR Filter_Condition (IndexCol1)
- When non-index and non-index columns are searched, indexes cannot be hit, and query performance is not improved.
Filter_Condition (IndexCol1) OR Filter_Condition (NonIndexCol1)
- During a combined query, if the outermost layer contains the OR condition, the index cannot be hit, and the query performance is not improved.
Filter_Condition (IndexCol1) OR Filter_Condition (NonIndexCol1) (Filter_Condition(IndexCol1)AND Filter_Condition (IndexCol2) )OR(Filter_Condition(NonIndexCol1))
Reduce the use of OR conditions, especially an OR condition used together with a range condition. Otherwise, large-scale data is queried in slow speed when indexes are hit.
