- Billing
- Getting Started
User Guide
HBase User Guide
HBase Cluster Management
- Overview
- Managing Clusters
- Preparing an ECS
- Using HBase
- HBase Cold and Hot Data Separation
- HBase Thrift Server
- HBase Security Channel Encryption
- HBase Batch Data Import
- HBase Monitoring Clusters
- Self-Healing from HBase Hotspotting
- Global Secondary Indexes
ClickHouse User Guide
ClickHouse Cluster Management
- Overview
- Managing ClickHouse Clusters
- Using ClickHouse
- Migrating ClickHouse Data
- ClickHouse User Management
- ClickHouse Role Management
- ClickHouse Slow Query Management
- Configuring Secure Channel Encryption for ClickHouse Clusters
- Application of ClickHouse Cold and Hot Data Separation
- ClickHouse Monitoring Clusters
- Permissions Management
- Audit Logs
- Cluster Log Management
HBase User Guide
Developer Guide
- HBase Application Development Guide
- ClickHouse Application Development Guide
General
- What Services Does a CloudTable Cluster Provide?
- Why Do I Choose CloudTable Service?
- How Do I Prepare for Creating a CloudTable HBase Cluster?
- What Should I Pay Attention to When Using CloudTable Service?
- What Compression Algorithms Are Supported by CloudTable HBase Clusters?
- Can I Stop CloudTable Service?
- Which Programming Languages Are Supported by HBase External APIs in CloudTable?
- How Do I Determine the Number of Faulty RegionServers?
- What Special Characters Does CloudTable HBase Support?
- What Can I Do If the Index Table Does Not Match the Data Table After CloudTable Data Is Deleted?
- What Should I Do If Concurrent Tasks Run Slowly When Python Accesses CloudTable Through Thrift?
- How do I view the TTL attribute of HBase shell?
- Why Are My Server Resources Released?
- How Do I Delete a Cluster?
- How Do I Stop Services and Release Resources?
Connection and Access
- How Do I Access a CloudTable Cluster?
- Can I Use SSH to Access Computing Nodes of CloudTable?
- Why Can't I Access HBase After the ZK Address Is Configured?
- Why Is the Error "Will not attempt to authenticate using SASL (unknown error)" Reported When Connecting to HBase?
- How Do I View the IP Address Corresponding to a Domain Name in a CloudTable Link?
- How Do I Access CloudTable from Other Cloud Services?
- Can I Configure the hbase-site.xml File?
- How Do I Query the Creation Time of a Table in CloudTable HBase?
Data Read/Write
- Is Raw Data Stored in CloudTable HBase?
- Why Can't I Write Data to HBase?
- What Is the Maximum Size of Data Written to the HBase Cluster?
- How Do I Check the Daily Incremental Data in HBase Tables?
- What Should I Do If an Error Is Reported When I Access the CloudTable HBase Cluster?
- How Do I Delete the Backup Table of the ZooKeeper Node in the ClickHouse Cluster?
- What Should I Do If a Database Missing Error Occurs When a Table Is Created in the ClickHouse Cluster?
- Billing FAQs
General
Show all
GSI APIs
APIs that use global indexes are packed in the org.apache.hadoop.hbase.hindex.global.GlobalIndexAdmin class. Related APIs are listed in the following table.
Operation |
API |
Description |
Adding an index |
addIndices() |
Adds a specified index to an empty table but skips index data generation. You can use this API to add indexes in batches to a table that contains a large amount of data and use the GlobalTableIndexer tool to build index data. |
addIndicesWithData() |
Adds a specified index to a table that contains data and generates index data for existing table data. You can call this API to generate an index and then generate index data when table data is being stored. This API is not recommended when a data table contains a large amount of data. |
Deleting an index |
dropIndices() |
Deletes both index metadata and index data. After deletion, the index cannot be used for scan or filter operations. |
Changing index status |
alterGlobalIndicesUnusable() |
Disables a specified index so that it cannot be used for the scan or filter operation. |
alterGlobalIndicesActive() |
Enables an index specified by the user so that it can be used for the scan or filter operation. |
alterGlobalIndicesInactive() |
Disables a specified index and skips index data generation so that it cannot be used for the scan or filter operation. This API is usually used for index data re-building. |
Viewing created indexes |
listIndices() |
Lists all indexes in a given table. |
