- Billing
- Getting Started
User Guide
HBase User Guide
HBase Cluster Management
- Overview
- Managing Clusters
- Preparing an ECS
- Using HBase
- HBase Cold and Hot Data Separation
- HBase Thrift Server
- HBase Security Channel Encryption
- HBase Batch Data Import
- HBase Monitoring Clusters
- Self-Healing from HBase Hotspotting
- Global Secondary Indexes
ClickHouse User Guide
ClickHouse Cluster Management
- Overview
- Managing ClickHouse Clusters
- Using ClickHouse
- Migrating ClickHouse Data
- ClickHouse User Management
- ClickHouse Role Management
- ClickHouse Slow Query Management
- Configuring Secure Channel Encryption for ClickHouse Clusters
- Application of ClickHouse Cold and Hot Data Separation
- ClickHouse Monitoring Clusters
- Permissions Management
- Audit Logs
- Cluster Log Management
HBase User Guide
Developer Guide
- HBase Application Development Guide
- ClickHouse Application Development Guide
General
- What Services Does a CloudTable Cluster Provide?
- Why Do I Choose CloudTable Service?
- How Do I Prepare for Creating a CloudTable HBase Cluster?
- What Should I Pay Attention to When Using CloudTable Service?
- What Compression Algorithms Are Supported by CloudTable HBase Clusters?
- Can I Stop CloudTable Service?
- Which Programming Languages Are Supported by HBase External APIs in CloudTable?
- How Do I Determine the Number of Faulty RegionServers?
- What Special Characters Does CloudTable HBase Support?
- What Can I Do If the Index Table Does Not Match the Data Table After CloudTable Data Is Deleted?
- What Should I Do If Concurrent Tasks Run Slowly When Python Accesses CloudTable Through Thrift?
- How do I view the TTL attribute of HBase shell?
- Why Are My Server Resources Released?
- How Do I Delete a Cluster?
- How Do I Stop Services and Release Resources?
Connection and Access
- How Do I Access a CloudTable Cluster?
- Can I Use SSH to Access Computing Nodes of CloudTable?
- Why Can't I Access HBase After the ZK Address Is Configured?
- Why Is the Error "Will not attempt to authenticate using SASL (unknown error)" Reported When Connecting to HBase?
- How Do I View the IP Address Corresponding to a Domain Name in a CloudTable Link?
- How Do I Access CloudTable from Other Cloud Services?
- Can I Configure the hbase-site.xml File?
- How Do I Query the Creation Time of a Table in CloudTable HBase?
Data Read/Write
- Is Raw Data Stored in CloudTable HBase?
- Why Can't I Write Data to HBase?
- What Is the Maximum Size of Data Written to the HBase Cluster?
- How Do I Check the Daily Incremental Data in HBase Tables?
- What Should I Do If an Error Is Reported When I Access the CloudTable HBase Cluster?
- How Do I Delete the Backup Table of the ZooKeeper Node in the ClickHouse Cluster?
- What Should I Do If a Database Missing Error Occurs When a Table Is Created in the ClickHouse Cluster?
- Billing FAQs
General
Show all
Introducing HBase Shell Commands
This section describes common HBase shell commands.
- Start the HBase shell.
Go to the HBase directory and run the following command to access the HBase shell:
./bin/hbase shell
- Get help information.
After you run the help command in the HBase shell, all command information as well as common command instructions and use methods will be returned.
hbase(main):001:0> help
- Create a table.
Run the create command to create a table. When creating a table, you must specify the table name and column family name.
hbase(main):007:0> create 'cloudtable','cf' 0 row(s) in 1.5530 seconds => Hbase::Table - cloudtable
- Query a table:
hbase(main):009:0> list TABLE cloudtable 1 row(s) in 0.0060 seconds => ["cloudtable"]
- Insert a piece of record to a table.
Run the put command to insert a piece of record to the specified table. You need to specify the table name, primary key, customized column, and inserted value.
hbase(main):004:0> put 'cloudtable','row1','cf:a','value1' 0 row(s) in 0.2720 seconds
The following describes parameters in the command:
- cloudtable: table name
- row1: primary key
- cf:a: customized column
- value1: inserted value
- Scan records
Run the scan command to scan a table. You need to specify the table name and you can scan a full table or specify a scanning range.
hbase(main):001:0> scan 'cloudtable' ROW COLUMN+CELL row1 column=cf:a, timestamp=1504866237162, value=value1 1 row(s) in 0.2420 seconds
- If the TTL of the cell is set when the data is inserted, the TTL attribute cannot be viewed. You can check whether the TTL configuration is successful.
- If the TTL of the cell is not set when data is inserted, the system automatically inserts the current time as the timestamp.
- Query a single record.
Run the get command to query a single record. The name and primary key of the queried table must be specified.
hbase(main):001:0> get 'cloudtable','row1' COLUMN CELL cf:a timestamp=1504866237162, value=value1 1 row(s) in 0.2280 seconds
- Disable a table.
Before modifying or deleting a table, you need to disable the table. Run the disable command to disable the table. When you perform operations on a disabled table, "ERROR" will be reported, indicating that the table is disabled.
hbase(main):002:0> disable 'cloudtable' 0 row(s) in 2.3550 seconds
- Enable a table.
If you want to use a table that has been disabled, run the enable command to enable the table.
hbase(main):004:0> enable 'cloudtable' 0 row(s) in 1.2500 seconds
- Delete a table.
Run the drop command to delete a table that you do not require anymore. Before deleting a table, disable the table. Otherwise, "ERROR" will be displayed, indicating that the table is enabled. Deleting a table will cause data loss. Therefore, exercise caution when deleting a table.
hbase(main):007:0> disable 'cloudtable' 0 row(s) in 2.2380 seconds hbase(main):008:0> drop 'cloudtable' 0 row(s) in 1.2600 seconds
- Exit the HBase shell.
Run the quit command to exit the HBase shell.
hbase(main):009:0> quit
