HBase Usage Process
Step |
Substep |
Description |
Detailed Instructions |
Preparations |
Creating a user and granting permissions |
Creating a cluster |
Creating an HBase cluster |
Before using HBase to execute tasks, you need to create an HBase cluster. |
Downloading the client |
Downloading the HBase client |
After creating a cluster, download and install the client. After the client is installed, you can use the SSH tool to connect to the cluster. |
Preparing an ECS |
If the client tool runs on Linux, you need to prepare a Linux ECS that is in the VPC as an HBase cluster and the Linux ECS serves as a client host. If the client tool runs on Windows, you need to prepare a Windows ECS that is in the VPC as an HBase cluster and the Windows ECS serves as a client host. |
Installing the client |
Place the downloaded client on the ECS, decompress the package, and install the client. |
Connecting to the cluster |
After installing the MySQL client on the ECS, you can run commands to connect to the cluster and perform service operations. |
