Deleting Files
Deleting Uploaded Files
Delete files uploaded to the VM, such as the .rpm packages of bms-network-config and SDI drivers.
Deleting Temporary Files
- Run the following commands to delete user login records:
echo > /var/log/btmp
 - Run the following commands to delete temporary files:
rm -rf /var/lib/cloud/*
rm -rf /var/log/network-config.log
rm -rf /opt/huawei/network_config/network_config.json
 - Delete residual configurations.
- SLES
Check for the files whose names start with ifcfg in the /etc/sysconfig/network-scripts/ folder and delete them except ifcfg-lo and ifcfg.template.
 - RHEL, CentOS, Oracle, or EulerOS
 - Ubuntu
 - SLES
 - Run the following command to delete operation records:
history -w;echo > /root/.bash_history;history -c;history -c;history -c;
