Stopping an iMetal Server
You can stop an iMetal server as needed.
- Stopping an iMetal server will forcibly interrupt services running on it. Before performing this operation, ensure that you have saved files on the iMetal server.
- You can stop an iMetal server only on the management console and cannot run shutdown to stop it. The shutdown and other commands attempting to stop an iMetal server will be regarded as unexpected operations and will not take effect.
The iMetal server must be started.
- Log in to the CloudDC console.
- In the navigation pane, choose Servers > iMetal Servers.
The iMetal Servers page is displayed.
- In the iMetal server list, locate your iMetal server and choose More > Stop in the Operation column.
To stop multiple iMetal servers, select them and click Stop at the top of the iMetal server list.
- In the Stop dialog box, confirm the information and click OK.
After the iMetal server is stopped, the iMetal server is in the Stopped state.
