Unit Test Agent
The unit test agent (developer-test-agent) is an end-to-end test case generation agent that provides core capabilities throughout the entire process, including test design, test case generation, and intelligent test case repair. This function can accurately generate test cases that comply with the code logic, automatically identify compilation errors of generated test cases, and intelligently repair test cases with compilation errors, effectively improving the development efficiency and quality of test cases.
Agent-based Unit Tests
The unit test agent works best with mainstream programming languages such as Java, C, C++, Go, Python, TypeScript, and JavaScript. The following demonstrates how to perform unit tests, using the TUI development environment as an example:
- Enter the TUI development environment.
- Open the root directory of the target project.
- Right-click in the blank area and select Open Windows Terminal here.
- In the terminal, enter codearts and press Enter to enter the TUI environment.
- In the chat box, enter a prompt (which must contain the keyword "developer-test-agent") to start the unit test.
Use developer-test-agent to generate unit tests for the main method in SnakeGame.java.
- Check whether a unit test file is generated. If yes, the execution is successful and the test is passed. Figure 1 Unit test result
