- User Guide
- Best Practices
Technologies
- How Do I Enable Cluster Protection?
- How Do I Disable Cluster Protection?
- What Should I Do If the Shield on a Node Is Offline?
- What Should I Do If I Have No Service Authorization Permissions or Fail to Create an Agency as an IAM User?
- How Often Are CGS Vulnerability Libraries Updated?
- When Does CGS Update and Back Up Logs?
- Where Can I Find My CGS Logs?
- Does the Shield Plug-in of CGS Affect My Services?
- Product Consultation
- Pricing
- Regions and AZs
- Change History
Technologies
Show all
CGS Permissions and Supported Actions
This section describes fine-grained permissions management for your CGS resources. If your Huawei Cloud account does not need individual IAM users, you can skip this section.
By default, new IAM users do not have permissions assigned. You need to add a user to one or more groups, and assign permissions policies to these groups. Users inherit permissions from their groups and can perform operations on cloud services as allowed by the permissions.
You can grant users permissions by using roles and policies. Roles are a type of coarse-grained authorization mechanism that defines permissions related to user responsibilities. Policies define API-based permissions for operations on specific resources under certain conditions, allowing for more fine-grained, secure access control of cloud resources.
Supported Actions
CGS provides system-defined policies that can be directly used in IAM. You can also create custom policies and use them to supplement system-defined policies, implementing more refined access control.
- Permission: a statement in a policy that allows or denies certain operations.
- Actions: added to a custom policy to control permissions for specific operations
Permission
Action
Related Action
Obtain CGS quota statistics.
cgs:quota:get
Obtain the yearly/monthly quota list.
cgs:quota:list
Subscribe to yearly/monthly CGS quota.
cgs:quota:operate
Query system process information.
cgs:cluster:list
- cce:addonInstance:*
- cce:node:list
- cce:cluster:list
Enable or disable protection for a container cluster.
cgs:cluster:operate
Query the image list.
cgs:images:list
Synchronize and scan images.
cgs:images:operate
Query container image information.
cgs:images:get
Query configurations.
cgs:configuration:list
Modify configurations.
cgs:configuration:operate
Query image security information.
cgs:imageSecure:list
Handle image security events.
cgs:imageSecure:operate
Obtain image scanning results.
cgs:imageSecure:get
Obtain the runtime event list.
cgs:runtimeSecure:list
Obtain runtime monitoring information.
cgs:runtimeSecure:get
Handle runtime monitoring events.
cgs:runtimeSecure:operate
Handle security agency authorization for CGS.
cgs:privilege:operate
Query CGS authorization.
cgs:privilege:get
