Viewing Audit Logs
Updated on 2022-04-06 GMT+08:00
After you enable CTS, the system starts recording operations on CGS. Operation records generated during the last seven days can be viewed on the CTS console.
Viewing a CGS Trace on the CTS Console
  2. In the navigation pane on the left, click and choose Management & Governance > Cloud Trace Service.
  3. Choose Trace List in the navigation pane on the left.
  4. Specify the filters used for querying traces. You can select one or more of the following filters to query your traces:
    • Trace Type, Trace Source, Resource Type, and Search By.
      Select the desired filter criterion from the drop-down list.
      • Set Trace Type to Management.
      • Set Trace Source to CGS.
      • When you select Trace name for Search By, you also need to select a specific trace name. When you select Resource ID for Search By, you also need to select or enter a specific resource ID. When you select Resource name for Search By, you also need to select or enter a specific resource name.
    • Operator: Select a specific operator (a user rather than tenant).
    • Trace Status: Available options include All trace statuses, normal, warning, and incident. You can only select one of them.
    • Time Range: In the upper right corner of the page, you can query traces in the last 1 hour, last 1 day, last 1 week, or within a customized period.
  5. Click Query.
  6. Click on the left of a trace to expand its details.
  7. Click View Trace in the Operation column. In the displayed View Trace dialog box, the trace structure details are displayed.
