- User Guide
- Best Practices
Technologies
- How Do I Enable Cluster Protection?
- How Do I Disable Cluster Protection?
- What Should I Do If the Shield on a Node Is Offline?
- What Should I Do If I Have No Service Authorization Permissions or Fail to Create an Agency as an IAM User?
- How Often Are CGS Vulnerability Libraries Updated?
- When Does CGS Update and Back Up Logs?
- Where Can I Find My CGS Logs?
- Does the Shield Plug-in of CGS Affect My Services?
- Product Consultation
- Pricing
- Regions and AZs
- Change History
Technologies
Viewing Unsafe Settings
CGS can scan your private image repository for unsafe configurations and provides suggestions for modifying the configurations, helping you fight intrusions and meet compliance requirements.
Check Frequency
CGS automatically performs a comprehensive check in the early morning every day.
The cluster protection function has been enabled.
- In the upper part of the page, select a region, click
, and choose Security & Compliance > Container Guard Service.
- In the navigation pane on the left, choose Image Security.
- Click the Unsafe Settings tab and view the detected risks. You can filter risks by level.
In the drop-down list in the upper right corner of the unsafe settings list, select All risk levels, High, Medium, or Low to check unsafe settings of the level.
Figure 1 Viewing unsafe settings - Click
next to a check item to view its details and suggestions, and modify your unsafe settings accordingly.
Figure 2 Check item details
