Container Guard Service
- User Guide
- Best Practices
Technologies
- How Do I Enable Cluster Protection?
- How Do I Disable Cluster Protection?
- What Should I Do If the Shield on a Node Is Offline?
- What Should I Do If I Have No Service Authorization Permissions or Fail to Create an Agency as an IAM User?
- How Often Are CGS Vulnerability Libraries Updated?
- When Does CGS Update and Back Up Logs?
- Where Can I Find My CGS Logs?
- Does the Shield Plug-in of CGS Affect My Services?
- Product Consultation
- Pricing
- Regions and AZs
- Change History
Technologies
On this page
Help Center/
Container Guard Service/
User Guide/
Image Security/
Viewing Malicious File Detection Results
CGS can automatically detect malicious files in the private images, helping you discover and eliminate the security threats in your assets.
Check Frequency
CGS automatically performs a comprehensive check in the early morning every day.
The cluster protection function has been enabled.
- In the upper part of the page, select a region, click
, and choose Security & Compliance > Container Guard Service.
- In the navigation pane on the left, choose Image Security.
- Click the Malicious Files tab to view details about malicious files in the private image repository, and delete the malicious files or create images again as needed based on the detection result.
- Malicious files include Trojan horses, worms, viruses, and adware.
- In the Image Tag column, click an image version to view its vulnerability report.
Figure 1 Malicious files
Parent topic: Image Security
