- User Guide
- Best Practices
Technologies
- How Do I Enable Cluster Protection?
- How Do I Disable Cluster Protection?
- What Should I Do If the Shield on a Node Is Offline?
- What Should I Do If I Have No Service Authorization Permissions or Fail to Create an Agency as an IAM User?
- How Often Are CGS Vulnerability Libraries Updated?
- When Does CGS Update and Back Up Logs?
- Where Can I Find My CGS Logs?
- Does the Shield Plug-in of CGS Affect My Services?
- Product Consultation
- Pricing
- Regions and AZs
- Change History
Technologies
Managing Local Images
Local images are container images that are used and started in the CCE cluster. CGS can scan these images. The local image list displays the basic information and security status of images.
This section describes how to view basic image information and vulnerability reports, and how to manage associated policies.
- CGS service authorization has been approved.
- The cluster protection function has been enabled.
Viewing Local Images
- In the upper part of the page, select a region, click
, and choose Security & Compliance > Container Guard Service.
- In the navigation pane on the left, choose Images.
- Click the Local Images tab.
Table 1 Local image parameters Parameter
Operation
Image Name
Image name
Click
next to the name of an image to view its versions.
Image ID
Image ID
Scan Status
Status of the image scan
Number of Vulnerabilities
Number of vulnerabilities detected in the image
Associated Policies
Number of policies applied in an image
Viewing Basic Information About a Local Image
- Click the Local Images tab and click an image name to view its basic information.
- View the basic information about the image version, as shown in Figure 1.
Viewing Vulnerabilities in Local Images
After the scanning is complete, you can view the vulnerability report.
- Click the Local Images tab. In the row containing the image whose vulnerability report you want to view, click View Report in the Operation column.
- On the Vulnerability Reports tab, check the detected image vulnerabilities.
You can perform the following operations:
- Check the number and percentage of vulnerabilities of each urgency level.
You can check the total number of vulnerabilities and the numbers of urgent and minor vulnerabilities.
- View vulnerabilities
You can view the vulnerability name, urgency, software information, vulnerability location, and solution.
- Search for vulnerabilities
In the upper part of the vulnerability list, you can select an urgency level (Repair now, Repair later, No repair required now) to filter vulnerabilities. You can also search for a vulnerability by its name or software information.
Both vulnerability and software names support fuzzy search.
- Viewing basic information about a vulnerability and the images affected by the vulnerability
Click a vulnerability name to go to the basic information page. Here you can view more details and the images affected by the vulnerability.
Figure 2 Vulnerability report - Check the number and percentage of vulnerabilities of each urgency level.
Applying a Policy to a Local Image
You can apply a policy to a local image.
- Click the Local Images tab and click an image name. The Basic Information page is displayed.
- Click the Associate Policies tab and click Apply Policy.
Figure 3 Applying a policy
- In the displayed dialog box, select the policy to be applied and click OK.
To cancel application of a policy, click Cancel Application in the Operation column of the policy.
