- User Guide
- Best Practices
Technologies
- How Do I Enable Cluster Protection?
- How Do I Disable Cluster Protection?
- What Should I Do If the Shield on a Node Is Offline?
- What Should I Do If I Have No Service Authorization Permissions or Fail to Create an Agency as an IAM User?
- How Often Are CGS Vulnerability Libraries Updated?
- When Does CGS Update and Back Up Logs?
- Where Can I Find My CGS Logs?
- Does the Shield Plug-in of CGS Affect My Services?
- Product Consultation
- Pricing
- Regions and AZs
- Change History
Technologies
Managing Official Image Vulnerabilities
This section describes how to view vulnerabilities in official images and rectify the vulnerabilities based on the suggestions.
CGS service authorization has been approved.
Viewing Vulnerability List
- In the upper part of the page, select a region, click
, and choose Security & Compliance > Container Guard Service.
- In the navigation pane on the left, choose Image Security.
- Click the Official Image Vulnerabilities tab.
- View the vulnerability percentage. View the number and percentage of vulnerabilities by the urgency level.
- Go to the official image vulnerability page. For details, see Table 1.
Table 1 Parameter description Parameter
Operation
Vulnerability Name
- Click
to view the details of a vulnerability, including CVE ID, CVSS Score, Disclosed, and Vulnerability Details.
- Click a vulnerability name to view the basic information and images affected by the vulnerability. For details, see 7.
Repair Urgency
Shows whether the vulnerability should be repaired immediately.
Affected Images
Shows the number of images that have been affected.
Solution
Provides a solution to fix the vulnerability.
Click the link in the Solution column to view the solution.
- Click
- Click a vulnerability name to view the basic information about the affected images, as shown in Figure 1 and Figure 2.
