- User Guide
- Best Practices
Technologies
- How Do I Enable Cluster Protection?
- How Do I Disable Cluster Protection?
- What Should I Do If the Shield on a Node Is Offline?
- What Should I Do If I Have No Service Authorization Permissions or Fail to Create an Agency as an IAM User?
- How Often Are CGS Vulnerability Libraries Updated?
- When Does CGS Update and Back Up Logs?
- Where Can I Find My CGS Logs?
- Does the Shield Plug-in of CGS Affect My Services?
- Product Consultation
- Pricing
- Regions and AZs
- Change History
Technologies
Show all
Disabling Protection for a Cluster
If CGS is not required, disable protection for a cluster by referring to this section.
Disabling protection will automatically uninstall the CGS plug-in from the cluster.
- CGS service authorization has been approved.
- Cluster Protection Status is Enabled.
- In the upper part of the page, select a region, click
, and choose Security & Compliance > Container Guard Service.
- Locate the row containing the target cluster and click Disable Protection in the Operation column.
Figure 1 Disabling protection
Click the name of a cluster to go to the node list page. You can also click Disable Protection on the top of the node list.
- In the displayed dialog box, click Yes.
After protection is disabled, Cluster Protection Status of the cluster is Disabled, indicating that protection has been disabled for all available nodes in the cluster.
