Updated on 2026-08-21 GMT+08:00
Intrusion Prevention Overview
Intrusion Prevention System (IPS) detects intrusion behavior based on the attack signature database and takes measures to block the intrusion in real time. CFW intrusion prevention can detect and block malicious traffic, including hacker attacks, vulnerability exploits, brute-force attacks, worms, mining programs, and Trojans in real time based on the experience and rules accumulated over the years. It helps you build a comprehensive cloud service security system, protecting enterprise core data and key services from unauthorized access, data leakage, and service interruptions.
Why Do We Need Intrusion Prevention?
Intrusion prevention is a necessary defense method to cope with the complex network threats. It largely reduces the intrusion risks for enterprises through real-time, intelligent threat blocking. The reasons for using IPS are as follows:
  • Defending against diverse complex network attacks
    Network threats have evolved from simple viruses to complex advanced persistent threats (APTs) and zero-day vulnerability exploits. Traditional firewalls and antivirus software cannot effectively defend against these advanced threats. Common means of attacks are as follows:
    • Malware attacks: Viruses, Trojans, ransomware, worms, or other malware attack cloud servers, often after they were unintentionally downloaded to the servers by users.
    • Port scans and brute-force attacks: Attackers deploy scan systems to scan servers worldwide for open ports, and attempt to guess the username and password by brute-force attacks to obtain unauthorized access. Attackers may also deploy Trojans, download mining programs, or ransomware on victims' servers.
    • Web vulnerability exploits: SQL injections, XSS attacks, CSRF attacks, and RCE vulnerabilities are included. Attackers exploit vulnerabilities in applications or websites to access target systems, tamper with data, or steal information.
    • Layer-4 vulnerability exploits: The attacks exploiting layer-4 network protocol vulnerabilities are included.
    • Database attacks: The attacks on databases such as Redis and MySQL are included.
    • Command executions and reverse shells: Attackers run malicious commands and reverse shells to obtain unauthorized access permissions.
    To cope with these threats, enterprises need to build a multi-layer security system. By deploying intelligent cloud firewalls, optimizing network access control policies, and establishing a quick vulnerability response mechanism, enterprises can comprehensively improve the security and stability of their business systems.
  • IPS Capabilities of Huawei Cloud CFW
    Huawei Cloud CFW IPS provides the following capabilities to enhance and facilitate protection on enterprise cloud services:
    • It protects your services against common network attacks based on the rules that are developed from security practices of the cloud platform and continuously updated.
    • CFW IPS monitors network traffic in real time. It proactively identifies and blocks network attacks, such as SQL injections and cross-site scripting (XSS), through packet inspection and behavior analysis.
    • You can customize IPS signatures. CFW will detect threats in data flows based on the signatures.
    • CFW IPS defends against sensitive directory scan attacks. After this function is enabled, the service can block scan attacks.
    • CFW IPS defends against reverse shell attacks. After this function is enabled, the service can block reverse shells.
CFW IPS Processing Flow
After protection is enabled, all network traffic accessing CFW is filtered by the CFWACL and IPS engines before being forwarded or directly discarded. During traffic detection, CFW identifies protocols and parses content to accurately analyze application layer behaviors. For detected potential threats:
  • They are matched with IPS attack signatures and threat intelligence through flow and packet filtering.
  • They are handled based on the preset protection mode (observation, lenient interception, medium interception, or strict interception).
  • Malicious traffic is blocked or allowed in real time, in strict compliance with the IPS rule library.
In this way, attacks can be reported and blocked in every stage of the process from protocol identification and threat detection to real-time blocking. The process is as follows:
Figure 1 Working process of IPS
  1. Packet reassembly: After receiving traffic, CFW reassembles IP fragments and TCP flows to ensure the continuity of application layer data and effectively detect the attacks that bypass intrusion prevention.
  2. Application protocol identification and parsing: The service identifies the application layer protocol based on the packet content and parses the protocol in depth to extract packet features.
  3. Signature matching: The service checks parsed packet features against intrusion prevention signatures. If a packet is matched, it is handled based on preset actions. CFW can periodically download the latest intrusion prevention signature databases from the Huawei Cloud security intelligence center to defend against network intrusions.
  4. Response: After a packet matches a signature, the IPS profile determines whether to respond to the packet and how to process the packet (alarm, block, or allow).
Notes and Constraints
  • Intrusion prevention does not support decryption detection and defense for TLS- and SSL-encrypted traffic.
  • If custom IPS rules have been added, IPS basic protection cannot be disabled.
  • If IPS basic protection is disabled, the virtual patch, sensitive directory scan prevention, and reverse shell detection prevention functions will be disabled with it.
Impacts on Services
If IPS blocking is enabled, a range of possible threats and suspicious traffic will be blocked. To change the protection mode, you are advised to enable the Observe mode and check false alarms for a period of time and then switch to the Intercept mode.
Attack Defense Types Supported By CFW
The following table lists the major types of attacks that can be defended against by CFW. For details about how to configure IPS, see Configuring Basic IPS Protection.
Attack Type
Impact
Access control
In access control attacks, attackers exploit access control vulnerabilities in systems or applications to illegally obtain or elevate their access permissions in the systems or applications, perform unauthorized operations, or access sensitive resources.
Access control attacks severely threaten system security. The major impacts are as follows:
  • Data leakage: Attackers can bypass the access control mechanism to obtain sensitive data, such as personal information and financial data, without authorization.
  • Data tampering: Attackers can bypass the access control mechanism to tamper with system data, generating false and unreliable data.
  • System breakdown: Attackers can bypass the access control mechanism to obtain administrator rights in the system, causing the system to be damaged or crashed.
  • Information security risks: Access control attacks damage the security mechanism in the system and increase information security risks, such as malware, virus, and Trojan attacks.
Hacker tool
A hack tool is a malware program used to launch network attacks. It is usually installed by hackers or malicious programs on victims computers to steal sensitive information, damage the system or network, and remotely control computers or networks. Hacker tools can also be legally used by security researchers to test the security of a system or network.
Abuse of hacker tools may bring huge security risks and economic losses to individuals and the society, including but not limited to the following:
  • Information theft: Hackers can steal personal and privacy information, such as accounts and passwords, bank account information, and social media accounts, causing property loss and privacy leakage.
  • System damage: Hackers can attack computer systems and damage system files and data, causing system breakdown or data loss.
  • Malicious attacks: Hacker tools can be used to launch malicious attacks, such as DDoS attacks and virus attacks, to make websites inaccessible or crash.
  • Cybercrime: Hacker tools can be used to carry out criminal activities, such as cyber fraud and cyber extortion, causing social security problems.
Suspicious DNS activity
Suspicious DNS activities refer to abnormal DNS requests or responses over the network. Attackers exploit DNS defects or send excessive requests to attack DNS. As a result, the DNS sends abnormal requests or responses, causing domain name resolution errors, resolution timeout, or DNS breakdown. This affects user experience and may also bring serious consequences such as economic losses and even legal liabilities.
Common suspicious DNS activities and their impacts include but are not limited to the following:
  • DNS cache poisoning: An attacker exploits the vulnerabilities of a DNS server to take over the DNS server. By tampering with the cache of the DNS server, the attacker redirects user access to malicious websites and launches attacks such as phishing and malware download.
  • DNS buffer overflow: An attacker exploits the vulnerabilities of the DNS server to send a large amount of malicious data to the cache of the server. As a result, the cache overflows and the malicious data overwrites the original valid data, causing attacks such as DNS response tampering, traffic redirection, and man-in-the-middle attacks.
Trojan
Trojans are a type of malware program that invades a computer to implement illegal intents. Trojans usually disguise as legitimate software and induce users to download them. Attackers use Trojans to control users' computer systems and steal personal information, passwords, or other sensitive data, or damage the computer systems.
Common Trojans and their harms include but are not limited to the following:
  • Remote control: Remote control is a basic function of Trojans. Without the victim's knowledge, an attacker can deliver commands to remotely control the victim's computer and complete attack instructions, such as tampering with files and data and downloading malware.
  • Password theft: This type of Trojan mainly collects all hidden passwords, such as the accounts and passwords of social accounts and online games, and sends out the password information without the victim's knowledge.
  • Keylogger: This type of Trojans can record keystrokes, through which an attacker can obtain useful information such as passwords. This type of Trojan is automatically loaded when the OS is started. It can be online or offline, recording users' keystrokes in online or offline states, respectively. Generally, a keylogger Trojan can send recorded information to a controller via email.
Vulnerability exploit
A vulnerability exploit refers to the behavior that attackers exploit security vulnerabilities in a system, software, or hardware to access the target system without authorization or damage it through well-constructed attack methods to achieve malicious purposes. These vulnerabilities are usually caused by defects in the design, implementation, or configuration process. They provide an opportunity for attackers to bypass security mechanisms.
The harms of vulnerability exploits include but are not limited to:
  • Economic loss: Vulnerability exploits may cause service interruption and data leakage, resulting in huge economic losses.
  • Information leakage: Attackers can exploit vulnerabilities to obtain sensitive information such as users' contacts and chat records, infringing on personal privacy.
  • Network damage: After successfully attacking a server, a hacker may turn the server into a zombie and use the zombie to attack other servers, expanding the attack scope.
  • Malware spread: Attackers may exploit vulnerabilities to implant malware, such as viruses and Trojans, into a victim's system to further damage system security.
Worm
A worm is a type of malware that can replicate itself and spread over the network. It scans for vulnerabilities on the network and exploits these vulnerabilities to infect other servers. Worms can exist and run without depending on other programs.
Worms pose serious threats to network security, including but not limited to:
  • System damage: Worms can damage system files and data, causing the system to crash or fail to work properly.
  • Information theft: Worms can steal sensitive user information, such as passwords and bank account information.
  • Abuse of network resources: Worms can use infected computers to launch DDoS attacks and send spam, causing network congestion and service unavailability.
  • Malware spread: Worms can use infected computers to spread other malware, such as Trojans and spyware.
Reverse shell
Reverse shells are a covert attack method. An attacker induces the victim server to initiate an outbound connection, bypassing traditional firewall restrictions to establish a remote control channel. Once successful, the attacker can completely control the target system, execute arbitrary commands, steal sensitive data, or implant backdoors. Reverse shells are often disguised as normal network traffic (such as HTTP and DNS) to evade traditional security devices. As a result, they may remain undetected for a long time. Such attacks may cause data leakage, system damage, and bring legal and compliance risks.
Sensitive directory scan
Sensitive directory scan is a common attack method. Attackers systematically access specific directories on websites or application servers to look for paths that may contain sensitive information or configuration files. In this way, attackers may obtain unauthorized access permissions and sensitive data, such as user information and configuration files. This may also cause server performance deterioration or even service interruption. Sensitive directory scan can also facilitate subsequent attacks, such as system penetration and website content tampering. These can severely harm enterprise security and reputation.
IPS Protection Modes
IPS can work in observation or interception mode. The mode influences the actions of basic protection rules and virtual patching rules. For example, if Intercept mode-strict is selected, the actions of most basic protection rules and virtual patching rules are Intercept. IPS protection modes are as follows:
  • Observe: Attacks are detected and recorded in logs.
  • Intercept: Attacks and abnormal IP address access are automatically intercepted.
Table 1 IPS protection modes
Category
Example Value
Observe
No protection.
Attacks are only recorded in Viewing Attack Event Logs and are not blocked.
Apache Druid remote code execution vulnerability (CVE-2021-25646), VMware Cloud Director remote code execution vulnerability (CVE-2020-3956), and Nero MediaHome DoS vulnerability (CVE-2012-5876)
Intercept
Low
High-threat and high-certainty attacks are blocked. Select it if you want to minimize false positives.
Attack characteristics (keywords and parameters) are accurately identified to match specific attack behaviors. No false positives are reported.
Command execution vulnerability in GNU Bash environment variable processing via DHCP (CVE-2014-6271), Microsoft SharePoint remote code execution vulnerability (CVE-2021-31181), and Delta Electronics DIAEnergie SQL injection vulnerability (CVE-2022-26013)
Medium
It meets protection requirements in most scenarios and is suitable for routine O&M.
Multiple types of attacks are covered, and multiple vulnerability analysis methods are integrated. In most cases, no false positives are reported.
Apache Commons Text remote code execution vulnerability (CVE-2022-42889) and Apache Flink remote code execution vulnerability
High
All the identified attack requests are blocked. Select it if you want to avoid false negatives.
Most high-risk vulnerabilities, such as stack overflow and buffer overflow, are layer-4 vulnerabilities. They need to be identified by analyzing protocols, matching keywords, and checking redirections and keyword offset.
Schneider Electric C-Bus directory traversal vulnerability (CVE-2021-22717), Apache SkyWalking GraphQL SQL injection vulnerability (CVE-2020-9483), and suspicious Trojan communication
Default actions of rule groups in different protection modes
Rule Group
Observe
Intercept mode - strict
Intercept mode - medium
Intercept mode - loose
Observe rule group
Observe
Disable
Disable
Disable
Strict rule group
Observe
Intercept
Disable
Disable
Medium rule group
Observe
Intercept
Intercept
Disable
Loose rule group
Observe
Intercept
Intercept
Intercept
The protective actions are as follows:
  • Observe: No rules are enabled. The firewall records the traffic that matches the current rule in Viewing Attack Event Logs and does not block the traffic.
  • Intercept: Rules are enabled. The firewall records the traffic that matches the current rule in Viewing Attack Event Logs and blocks it.
  • Disable: Rules are disabled. The firewall does not log or block the traffic that matches the current rule.
