Help Center/ Cloud Firewall/ User Guide/ Access Control/ Configuring Internet Border Protection Rules/ Example 3: Allowing Traffic from a Service to a Platform
Updated on 2026-08-21 GMT+08:00
This section describes how to allow traffic from a service to a platform. For more parameter settings, see Configuring Protection Rules to Block or Allow Internet Border Traffic.
Domain Name Group Types
CFW provides two types of domain name groups: application domain name groups (layer 7 protocol parsing) and network domain name groups (layer 4 protocol parsing). Table 1 describes the differences between them.
Table 1 Domain name group types
Application Domain Name Group (Layer 7 Protocol Parsing)
Network Domain Name Group (Layer 4 Protocol Parsing)
Protected object
  • Domain names
  • Wildcard domain names
  • A single domain name
  • Multiple domain names
Protocol Type
Application layer protocols, including HTTP, HTTPS, TLS1, SMTPS, and POP3S.
Network layer protocols. All protocol types are supported.
Match rule
The match is based on domain name. The service compares the HOST field in sessions with the application domain names. If they are consistent, the corresponding protection rule is hit.
The filtering is based on the resolved IP addresses.
The service obtains the IP addresses resolved by DNS every 15 seconds. If the four-tuple of a session matches the network domain name rule and the resolved address has been saved (that is, the IP address has been obtained from the DNS server), the corresponding protection rule is hit.
Suggestion
You are advised to use the application domain name group (for example, the domain name accelerated by CDN) for the domain names that have a large number of mapping addresses or rapidly changing mapping results.
To allow an EIP (xx.xx.xx.48) to access cfw-test.com and *.example.com, configure parameters as follows. The parameters not mentioned below can be configured as needed.
  • Create an application domain name group and configure the platform domain names. An example is as follows:
    Figure 1 Adding the domain name group of a platform
    Table 2 Adding the domain name group of a platform
    Example Value
    Application
    Select a domain name group type.
    Group Name
    Platform_A
    Name of a user-defined domain name group.
    Domain names
    cfw-test.com
    *.example.com
    Enter a domain name or wildcard domain name. Use commas (,), line breaks, semicolons (;), or spaces to separate multiple domain names.
    Allow traffic from a service to a platform.
    Describe the content and application scenarios of the current domain name group.
  • Configure the following protection rules:
    • The following rule blocks all traffic and has the lowest priority.
      Figure 2 Blocking all traffic
      Table 3 Blocking all traffic
      Example Value
      Direction
      Outbound
      Direction of the protected traffic.
      Source
      Any
      Origin of network traffic.
      Destination
      Any
      Receiver of network traffic.
      Service
      Any
      Protocol, source port, and destination port of network traffic.
      Application
      Any
      Protection policy for application layer protocols.
      Action
      Block
      Action taken when traffic passes through the firewall.
    • The other rule allows the traffic from the EIP to the platform. The priority is the highest. An example is as follows:
      Figure 3 Allowing the traffic from an EIP to a platform
      Table 4 Allowing the traffic from an EIP to a platform
      Example Value
      Direction
      Outbound
      Source
      IP Address/IP address group
      IP Address
      xx.xx.xx.48
      Destination
      IP Address/IP address group/Countries and regions/Domain name/Domain name group
      Application, Application Domain Name Group, X_platform
      Service
      Service. Retain the default values for other parameters.
      Application
      Application: HTTP and HTTPS
      Action
      Allow
Follow-up Operations
Checking protection outcomes: After your services run for a period of time, you can check the protection rule hits and adjust them in time.
References
