Help Center/ Cloud Firewall/ User Guide/ Access Control/ Configuring Internet Border Protection Rules/ Example 1: Allowing the Inbound Traffic from a Specified IP Address
Updated on 2026-09-14 GMT+08:00
This section describes how to allow access traffic from a specified IP address in the inbound direction. For more parameter settings, see Configuring Protection Rules to Block or Allow Internet Border Traffic.
Configure two protection rules. One of them blocks all traffic. Its priority is the lowest. The other allows the traffic of a specified IP address, and its priority is the highest. Configure other parameters as needed.
  • One of them blocks all traffic and has the lowest priority. Configure the following parameters as suggested, and configure other parameters as needed.
    Figure 1 Blocking all traffic
    Table 1 Blocking all traffic
    Example Value
    Direction
    Inbound
    Direction of the protected traffic.
    Source
    Any
    Origin of network traffic.
    Destination
    Any
    Receiver of network traffic.
    Service
    Any
    Protocol, source port, and destination port of network traffic.
    Application
    Any
    Protection policy for application layer protocols.
    Protection Action
    Block
    Action taken when traffic passes through the firewall.
  • The other rule allows traffic from a specified IP address to pass through and has the highest priority. Configure the following parameters as suggested, and configure other parameters as needed.
    Figure 2 Allowing a specified IP address
    Table 2 Allowing a specified IP address
    Example Value
    Direction
    Inbound
    Source
    IP Address/IP address group/Countries and regions
    IP Address
    192.168.0.0
    Destination
    Any
    Service
    Any
    Application
    Any
    Protection Action
    Allow
Follow-up Operations
Checking protection outcomes: After your services run for a period of time, you can check the protection rule hits and adjust them in time.
References
