Purchasing a Pay-per-Use CFW
Pay-per-use billing is a postpaid billing mode. A pay-per-use CFW can be provisioned and deleted at any time. CFW instances are billed by second. The system generates a bill every hour based on the protected traffic and deducts the billed amount from the account balance.
You can purchase multiple firewalls in a region and assign them different resources and policies.
Only the professional edition in certain regions can be billed in pay-per-use mode. For details about the regions that support pay-per-use billing, see Function Overview.
To use an IAM user, ensure the IAM user has been granted the BSS Administrator and CFW FullAccess permissions. For details, see Creating a User Group and Granting Permissions.
- CFW can be used only in the region selected during purchase. To use it in another region, switch to the corresponding region and then purchase it. The pay-per-use billing mode firewall is supported only in certain regions. For details, see Function Overview.
- The maximum protection bandwidth is 1 Gbit/s. (It refers to the total traffic passing through the firewall, that is, the Internet border protection bandwidth plus the VPC border protection bandwidth).
- Only the CFW professional edition supports pay-per-use billing.
Purchasing a Pay-per-Use Professional CFW
- Click
in the upper left corner of the management console. Select a region.
- In the navigation pane on the left, click
and choose . The Dashboard page will be displayed.
- Click Buy CFW. The Buy CFW page is displayed.
Table 1 Parameters for CFW Parameter
Billing Mode
If you select Pay-per-use, you will be charged for the protection on your workloads from purchase to unsubscription.
Region
Region where the CFW is to be purchased.
CFW can be used in the selected region only. To use CFW in another region, switch to the corresponding region and then purchase it. For details about the regions where CFW is available, see Can CFW Be Used Across Clouds or Regions?
Edition
Currently, only the professional edition is supported.
Firewall Name
Firewall name.
It must meet the following requirements:- Only letters (A to Z and a to z), numbers (0 to 9), spaces, and the following characters are allowed: -_
- The value can contain 1 to 48 characters.
Enterprise Project
Enterprise project. Select the enterprise project that you belong to from the drop-down list. The purchased CFW instance will be put under that enterprise project for billing management, and will be able to protect the resources of all enterprise projects.
This option is only available if you have enabled enterprise projects, or if you are logged in using an enterprise master account. To use this function, enable Enterprise Center. You can use an enterprise project to centrally manage your cloud resources and members by project.
Value default indicates the default enterprise project. The original resources of your account and the resources that are not allocated to any enterprise projects under your account are displayed in the default enterprise project.
Tags
(Optional) It is recommended that you use the TMS predefined tag function to add the same tag to different cloud resources.
If your organization has configured a tag policy for CFW, you need to add tags in compliance with the policy. If a tag does not comply with the tag policies, firewall instance creation may fail. Contact your organization administrator to learn more about tag policies.
- Confirm the information and click Next.
- Confirm the order details, select I have read and agreed to the Huawei Cloud Firewall Service Statement, and click Next.
- Select a payment method and pay for your order.
Effective Conditions
After the payment is successful, you can view the purchased firewall edition on the Dashboard page of the console.
References
- For details about how to view the basic information and overall protection capabilities of a firewall instance, see CFW Dashboard.
- If the current firewall specifications cannot meet service requirements, you can upgrade the firewall edition or purchase an expansion package. For details, see Upgrading a CFW and Changing the Number of CFW Expansion Packages.
- For details about how to purchase a yearly/monthly firewall, see Purchasing Yearly/Monthly Cloud Firewall.
- If you no longer need the firewall, unsubscribe from it. For details, see Unsubscribing from CFW.
