Restoring the Enterprise Router Configuration After VPC Border Protection Is Permanently Disabled
If you no longer need VPC border traffic protection, manually restore the configuration of the enterprise router after disabling VPC border protection.
This section describes how to restore enterprise router configurations. After the restoration, traffic will be transmitted from VPC1 to VPC2 through the enterprise router without passing through CFW.
If you disable VPC protection and restore the enterprise router configuration, CFW will not protect the traffic between VPCs. Exercise caution when performing this operation.
The protection from the VPC border firewall is no longer required.
Restoring Enterprise Router Configurations
- Disable VPC border firewall protection. For details, see Disabling VPC Border Protection.
- In the upper left corner, click
and choose Networking > Enterprise Router. Click Manage Route Table.
- Configure propagation routes (automatically generated after propagation is configured) in the association route table.
- On the Routes tab page of the association route table, click Create Route. Set Destination Address and Next Hop to those of the protected VPC specified in the configurations of the propagation route table.
- An association route table is used for transmitting traffic from VPC to CFW. For details about how to configure it, see 7.
A propagation route table is used for transmitting traffic from CFW to VPC. For details about how to configure it, see 8.
- The number of routes added to the association route table must be the same as the number of routes displayed in the propagation route table.
- (Optional) Delete the propagation route table.
This step is optional. Traffic will be transmitted from VPC1 to VPC2 through the enterprise router even if the propagation route table is not deleted.
- For more information about how to delete a CFW connection, see Submitting a Service Ticket.
