Yearly/Monthly payment is a prepaid billing mode and is cost-effective for long-term use.
You can purchase multiple firewalls in a region and assign them different resources and policies.
- CFW can be used only in the region where it was purchased. To use it in another region, switch to that region and purchase it.
Editions
CFW supports the yearly/monthly (prepaid) and pay-per-use billing modes.
- Yearly/Monthly CFW instances support the standard edition, and professional edition.
- Pay-per-use CFW instances support the professional edition.
For details about the differences between editions, see Editions.
The application scenarios for different editions are as follows:
- Standard edition
Suitable for small- and medium-sized enterprises that need to defend against cybersecurity threats like network intrusions and server compromises, or need to obtain Multi-Layer Protection Scheme (MLPS) certification.
- Professional edition
Suitable for large and medium-sized enterprises that need to defend against network intrusions and server compromises, control internal network security, obtain MLPS certification, or have key event assurance requirements.
Purchasing CFW
Perform the following operations to purchase a firewall instance of the desired edition.
Standard Edition Firewalls
- Log in to the CFW console.
- Click
in the upper left corner of the management console and select a region or project.
- Click Buy CFW and configure parameters on the Buy CFW page. The following table describes parameters.
Table 1 Parameters for purchasing the standard edition CFW
Parameter |
Description |
Basic Settings |
Billing Mode |
Yearly/Monthly. You will be billed based on the selected period. |
Region |
Region where the CFW is to be purchased.
CFW can be used in the selected region only. To use CFW in another region, switch to the corresponding region and then purchase it. For details about the regions where CFW is available, see Can CFW Be Used Across Clouds or Regions? |
Edition |
Select the standard edition. |
Extended Packages |
Protected EIPs |
(Optional) The number of additional EIPs to be protected. Value range: 0 to 2,000.
Configure additional capacities to purchase. For example, 20 EIPs are protected by the standard edition (included in the package fee) by default. If you have 65 EIPs, you only need to enter 45. |
Internet Border Protection Bandwidth |
(Optional) Additional peak inbound or outbound traffic. The value range is 0 to 50,000 Mbit/s per month. (The value must be an integer multiple of 5.)
- Configure additional capacities to purchase. For example, up to 10 Mbit/s is protected by the standard edition (included in the package fee) by default. If your protection traffic is 200 Mbit/s, you only need to enter 190.
- The protection traffic is determined based on the maximum inbound or outbound traffic, whichever is higher.
Resource Management |
Firewall Name |
Firewall name.
It must meet the following requirements:
- Only letters (A to Z and a to z), numbers (0 to 9), spaces, and the following characters are allowed: -_
- The value can contain 1 to 48 characters.
Enterprise Project |
Enterprise project. In the drop-down list, select an enterprise project. The firewall will be put under that enterprise project for billing management, but its protection scope will not be affected. The firewall can protect the resources of all enterprise projects.
This option is only available if you have enabled enterprise projects, or if you are logged in using an enterprise master account. To use this function, enable Enterprise Center. You can use an enterprise project to centrally manage your cloud resources and members by project.
Value default indicates the default enterprise project. The original resources of your account and the resources that are not allocated to any enterprise projects under your account are displayed in the default enterprise project. |
Tags |
(Optional) You can use a tag for multiple cloud resources. You are advised to predefine tags in TMS. For details, see Resource Tag Overview.
If your organization has configured a tag policy for CFW, you need to add tags in compliance with the policy. If a tag does not comply with the tag policies, firewall instance creation may fail. Contact your organization administrator to learn more about tag policies. |
Required Duration |
Service duration.
After selecting a duration, you can select Auto-renew. If you select and agree to service auto-renewal, the system automatically generates a renewal order based on the subscription period and renews the service before it expires. Note the Auto-Renewal Rules when enabling auto-renewal. |
- Confirm the information and click Next.
- Confirm the order details, select I have read and agreed to the Huawei Cloud Firewall Service Statement, and click Next.
- Select a payment method and pay for your order.
Professional Edition Firewalls
- Click
- Click Buy CFW and configure parameters on the Buy CFW page. Below are the parameter details.
Table 2 Parameters for purchasing the professional edition CFW
Parameter |
Description |
Basic Settings |
Billing Mode |
Region |
Edition |
Edition. Select the professional edition. |
Extended Packages |
Protected EIPs |
Configure additional capacities to purchase. For example, 50 EIPs are protected by the professional edition (included in the package fee) by default. If you have 65 EIPs, you only need to enter 15. |
- Configure additional capacities to purchase. For example, up to 50 Mbit/s per month is protected by the professional edition (included in the package fee) by default. If your protection traffic is 200 Mbit/s per month, you only need to enter 150.
Protected VPCs |
(Optional) Select the number of VPCs to be expanded. The value ranges from 0 to 1,000.
- Only the professional edition supports inter-VPC protection.
- By default, two VPCs are protected by the professional edition (included in the package fee). If you have three VPCs, you only need to enter 1.
- For each VPC you add, the protected peak traffic increases by 200 Mbit/s.
Firewall Name |
Firewall name.
Tags |
Required Duration |
Service duration.
Effective Conditions
After the payment is successful, you can view the purchased firewall edition on the Dashboard page of the console.
