Updated on 2024-10-22 GMT+08:00
Viewing a Predefined Service Group
CFW provides predefined service groups, including Web Service, Database, and Remote Login and Ping, suitable for protecting web services, databases, and servers, respectively.
You can only view predefined service groups, but cannot add services to it, or modify or delete it.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, click and choose Security & Compliance > Cloud Firewall. The Dashboard page will be displayed.
  4. (Optional) Switch firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
  5. In the navigation pane, choose Access Control > Object Groups.
  6. Click the Service Groups tab. Click the Pre-defined Service Groups tab and click the name of a service group. On the details page that is displayed, view the service group information.
