Help Center/
Cloud Firewall/
User Guide/
CFW Protection/
Enabling VPC Border Traffic Protection/
Enterprise Router Mode (Old)/
Enabling or Disabling a VPC Border Firewall
Updated on 2025-06-27 GMT+08:00
A new firewall is disabled by default. Traffic passes through the enterprise router without being forwarded to the new firewall. You can enable or disable a VPC border firewall as needed.
- You have purchased the CFW professional edition.
- You have configured an enterprise router.
- Only the professional edition supports inter-VPC firewall protection.
- Click
in the upper left corner of the management console and select a region or project.
- In the navigation pane on the left, click
and choose . The Dashboard page will be displayed.
- (Optional) Switch to another firewall instance. Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation pane, choose Assets > Inter-VPC Border Firewalls.
- In the Operation column, click Enable Protection or Disable Protection.
