Help Center/ Cloud Firewall/ User Guide/ Traffic Analysis/ Viewing Inter-VPC Traffic
Updated on 2025-11-20 GMT+08:00
The Inter-VPC Access page displays the traffic between the protected VPCs.
VPC border traffic protection is enabled, and there is already traffic passing through the VPC. For details, see Enabling VPC Border Traffic Protection.
  1. Log in to the CFW console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. (Optional) Switch to another firewall instance. Select a firewall from the drop-down list in the upper left corner of the page.
  4. In the navigation pane, choose Traffic Analysis > Inter-VPC Access.
  5. Check the statistics on the traffic passing through CFW within a time range, from 5 minutes to 7 days.
    • Traffic Dashboard: Information about the maximum traffic between VPCs.
      Figure 1 Inter-VPC access traffic - traffic dashboard
    • Inter-VPC Access: Request and response traffic between VPCs.
      The data displayed is the average bits per second (bps) of the sessions ended at the specified time in traffic logs.
      Figure 2 Inter-VPC access
      Table 1 Value description
      Time Range
      Last 1 hour
      Average value within every minute
      Last 24 hours
      Average value within every 5 minutes
      Last 7 days
      Average value within every hour
      Custom
      • 5 minutes to 6 hours: average value within every minute
      • 6 hours (included) to 3 days: average value within every 5 minutes
      • 3 (included) to 7 days (included): average value within every 30 minutes
    • Visualizations: View the top 5 items ranked by specific parameters of inter-VPC traffic within a specified period. For more information, see Table 2. You can click a data record to view the traffic details. A maximum of 50 data records can be viewed.
      Figure 3 Inter-VPC access traffic - visualized statistics
      Table 2 Inter-VPC traffic parameters
      Top Access Source IP Addresses
      Source IP address of inter-VPC traffic.
      Top Destination IP Addresses
      Destination IP addresses of inter-VPC traffic.
      Top Open Ports
      Destination port of inter-VPC traffic.
      Application Distribution
      Application information about inter-VPC traffic.
    • Private IP Address Accesses: Top 50 private IP addresses with the highest traffic within a specified period.
      Figure 4 Private IP address accesses
References
