Updated on 2026-07-15 GMT+08:00
Alarm Notification
CFW alarm notification monitors the running status and risks of CFW in real time. When detecting attacks, unprotected EIPs, or other risks, the service sends SMS or email notifications to specified recipients, helping them detect and handle threats in time and enhance asset security.
Simple Message Notification (SMN) is a paid service. For details, see Product Pricing Details.
Alarm Notification Items
CFW supports the following alarm notification items:
Table 1 Alarm notification items
Attack Alarm
When CFW detects an intrusion (such as port scan, SQL injection, or malicious code attack) and the preset triggering conditions are met, an alarm notification is sent.
High Traffic Warning
If the peak traffic passing through CFW reaches a certain percentage (for example, 70%, 80%, or 90%) of the purchased traffic processing capacity, and such excess occurs three or more times within 5 minutes, an alarm notification will be sent. (The notification is sent only once every day.)
EIP Not Protected
If CFW detects unprotected EIPs under your account, it will send an alarm notification once a day. (The notification is sent only once every day.)
Abnormal External Connection Alarm
If CFW detects suspicious behavior of IP addresses or domain names that may be used for external connections and the trigger conditions are met, it will send an alarm notification.
Abnormal external connection alarms are supported only in certain regions. For details, see the regions displayed on the console.
Notes and Constraints
  • Abnormal external connection alarms are supported only in certain regions. For details, see the regions displayed on the console.
  • Alarms about unprotected EIPs and high traffic warnings are sent only once a day.
  • Alarm notifications depend on the SMN service. If no subscriptions are created and confirmed for the SMN topic, you will not receive any notifications.
    Before setting alarm notifications, you are advised to create a topic and add subscriptions in SMN. For details, see Creating a Topic and Adding a Subscription.
Setting Alarm Notifications
You can set the alarm notification time, trigger condition, and recipient group, so that CFW can send notifications to recipients in the specified period of time using the method you configure (for example, by email or SMS message).
Related Operations
If there are unprotected EIPs that do not need to trigger alarms, you can add them to the alarm whitelist to reduce invalid alarms, alleviating the impact on O&M or other functions. The operations are as follows:
  1. In the Operation column of the EIP Not Protected alarm, click Add to Alarm Whitelist.
  2. On the displayed page, select the target EIP and add it to the list on the right.
  3. Click OK.
    After the EIP is added to the whitelist, no alarm notifications will be sent even if the EIP is not protected.
