Configuring Alarm Monitoring Rules
You can set CFW alarm rules to customize the monitored objects and notification policies, and set parameters such as the alarm rule name, monitored object, metric, threshold, monitoring scope, and whether to send notifications. This helps you learn the CFW protection status in a timely manner.
- Log in to the Cloud Eye console.
- Click
in the upper left corner of the management console and select a region or project. - In the navigation pane on the left, choose Alarm Management > Alarm Rules.
- In the upper right corner of the page, click Create Alarm Rule.
- Configure parameters as prompted.
Key parameters are described below. For more information, see Creating an Alarm Rule.
- Name: Enter a name.
- Alarm Type: Select Metric.
- Cloud Product: Select CFW - CFW Instances.
- Resource Level: Select Cloud product.
- Monitoring Scope: Select All resources.
- Method: Select Associated template or create a custom template.
- Alarm Notifications: If you want to receive alarms in real time, enable this option and select a notification mode.
- Other parameters: Set them based on site requirements.
- Click Create.
