CFW Monitored Metrics
This topic describes metrics reported by CFW to Cloud Eye as well as their namespaces and dimensions. You can use APIs provided by Cloud Eye to query the metrics of the monitored object and alarms generated for CFW. You can also query them on the Cloud Eye console.
Namespace
SYS.CFW
A namespace is an abstract collection of resources and objects. Multiple namespaces can be created in a single cluster with the data isolated from each other. This enables namespaces to share the same cluster services without affecting each other.
- internet_protection_traffic
- vpc_protection_traffic
- internet_protection_traffic_inbound
- internet_protection_traffic_outbound
- ips_allow_count
Metrics
The metrics described in Table 1 are old. You are advised to use the metric in Table 2.
| Metric ID | Metric Name | Description | Value Range | Unit | Number System | Dimension | Monitoring Period (Original Metric) |
| used_protection_bandwidth | Boundary Protection Bandwidth Usage (Mbps) | Used Internet bandwidth detected by CFW in the last 5 minutes | ≥ 0 Value type: Float | KB/s | 1000(SI) | fw_instance_id | 5 minutes |
| protection_bandwidth_usage | Boundary Protection Bandwidth Usage (%) | Internet bandwidth usage rate detected by CFW within 5 minutes. Usage rate = Used bandwidth/Bandwidth quota | ≥ 0 Value type: Float | Percentage | N/A | fw_instance_id | 5 minutes |
| internet_protection_bandwidth_usage | Internet Boundary Protection Bandwidth Usage (Mbps) | Bandwidth usage (Mbps) for protection at the Internet boundary. | ≥ 0 Value type: Float | Bit/s | 1000(SI) | fw_instance_id | Every minute |
| vpc_protection_bandwidth_usage | Inter-VPC Protection Bandwidth Usage (Mbps) | Bandwidth usage (Mbps) for inter-VPC protection. | ≥ 0 Value type: Float | Bit/s | 1000(SI) | fw_instance_id | Every minute |
| internet_protection_bandwidth_usage_rate | Internet Boundary Protection Bandwidth Usage (%) | Bandwidth usage (%) for protection at the Internet boundary. | ≥ 0 Value type: Float | % | N/A | fw_instance_id | Every minute |
| vpc_protection_bandwidth_usage_rate | Inter-VPC Protection Bandwidth Usage (%) | Bandwidth usage (%) for inter-VPC protection. | ≥ 0 Value type: Float | % | N/A | fw_instance_id | Every minute |
| internet_protection_pps | Internet Boundary Firewall PPS | PPS of protected objects at the Internet border. | ≥ 0 Value type: Float | / | N/A | fw_instance_id | Every minute |
| vpc_protection_pps | Inter-VPC Firewall PPS | PPS of inter-VPC protected objects. | ≥ 0 Value type: Float | / | N/A | fw_instance_id | Every minute |
| ips_hit_count | IPS Rule Hits | Number of times that traffic matches IPS rules. | ≥ 0 Value type: Int | / | N/A | fw_instance_id | Every minute |
| ips_deny_count | IPS Rule Block Count | Number of times that traffic is blocked based on IPS rules. | ≥ 0 Value type: Int | / | N/A | fw_instance_id | Every minute |
| acl_hit_count | ACL Rule Hits | Number of times that traffic matches ACL rules. | ≥ 0 Value type: Int | / | N/A | fw_instance_id | Every minute |
| acl_deny_count | ACL Rule Block Count | Number of times that traffic is blocked based on ACL rules. | ≥ 0 Value type: Int | / | N/A | fw_instance_id | Every minute |
| internet_protection_bandwidth_usage_inbound | Inbound Protection Bandwidth | Inbound Internet protection bandwidth of the firewall. | ≥ 0 Value type: Float | Bit/s | 1000(SI) | fw_instance_id | Every minute |
| internet_protection_bandwidth_usage_outbound | Outbound Protection Bandwidth | Outbound Internet protection bandwidth of the firewall. | ≥ 0 Value type: Float | Bit/s | 1000(SI) | fw_instance_id | Every minute |
| internet_protection_bandwidth_usage_rate_inbound | Inbound Protection Bandwidth Usage | This metric = Inbound Internet protection bandwidth of the firewall/Internet Border Protection Bandwidth | ≥ 0 Value type: Float | % | N/A | fw_instance_id | Every minute |
| internet_protection_bandwidth_usage_rate_outbound | Outbound Protection Bandwidth Usage | Outbound Internet protection bandwidth usage (%). | ≥ 0 Value type: Float | % | N/A | fw_instance_id | Every minute |
| internet_protection_pps_inbound | Inbound PPS | PPS of Internet access to firewall-protected objects. | ≥ 0 Value type: Float | / | N/A | fw_instance_id | Every minute |
| internet_protection_pps_outbound | Outbound PPS | PPS of firewall-protected objects accessing the Internet. | ≥ 0 Value type: Float | / | N/A | fw_instance_id | Every minute |
| internet_protection_traffic | Internet Protection Traffic | Traffic of the protected objects of a firewall. | ≥ 0 Value type: Float |
| vpc_protection_traffic | Inter-VPC Protection Traffic | Traffic between the VPCs protected by a firewall. | ≥ 0 Value type: Float |
| internet_protection_traffic_inbound | Inbound Internet Protection Traffic | Inbound Internet protection traffic of a firewall. | ≥ 0 Value type: Float |
| internet_protection_traffic_outbound | Outbound Internet Protection Traffic | Outbound Internet protection traffic of a firewall. | ≥ 0 Value type: Float |
| ips_allow_count | IPS Rule Allow Count | Number of times that traffic is allowed based on IPS rules. | ≥ 0 Value type: int | / | N/A | fw_instance_id | Every minute |
Dimension
| Key | Value |
| fw_instance_id | A firewall ID is a CFW instance ID. It is automatically generated by the system after CFW is created. You can obtain the value of this parameter by referring to Querying the Firewall List.
