Adding a Custom Service Group
A service group is a collection of services (protocols, source ports, and destination ports). A service group frees you from repeatedly modifying access rules and simplifies security group rule management.
- A service group can have up to 64 services.
- A firewall instance can have up to 512 service groups.
- A firewall instance can have up to 900 services.
- Click in the upper left corner of the management console and select a region or project.
- In the navigation pane on the left, click and choose . The Dashboard page will be displayed.
- (Optional) Switch firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation pane, choose .
- Click the Service Groups tab. Click Add Service Group and configure parameters in the Add Service Group area. Enter the service group name and description.
Table 1 Service group parameters Parameter
Service Group Name
Name of a service group
Usage and application scenario
Services
- Protocol: Select a protocol. Supported protocols include TCP, UDP, and ICMP.
- Source Port: Set the source port to be allowed or blocked. You can configure a single port or consecutive port groups (example: 80-443).
- Destination Port: Set the destination port to be allowed or blocked. You can configure a single port or consecutive port groups (example: 80-443).
- Description: Usage and application scenario of the service group
- Confirm the information and click OK.
Adding a Service to a Custom Service Group
- Click the Service Groups tab. Click the name of a service group. The Service Groups slide-out panel is displayed.
- Click Add Service. The Add Service dialog box is displayed.
Table 2 Adding a service Parameter
Example Value
Protocol
Its value can be TCP, UDP, or ICMP.
TCP
Source Port
Source ports to be allowed or blocked. You can configure a single port or consecutive port groups (example: 80-443).
NOTE:If Protocol is set to ICMP, you do not need to specify any port number.
80
Destination Port
Destination ports to be allowed or blocked. You can configure a single port or consecutive port groups (example: 80-443).
80
- You can click Add to add multiple services.
Related Operations
- Exporting service address groups: Click Export above the list.
- Batch deleting services: Select services on the service group page and click Delete above the list.
Follow-up Operations
A service group takes effect only after it is set in a protection rule. For more information, see Adding Protection Rules to Block or Allow Traffic.
