Adding Custom IP Address and Address Groups
An IP address group contains multiple IP addresses. An IP address group frees you from repeatedly modifying access rules and allows you to manage access rules in batch.
- A firewall instance can contain up to 3800 IP address groups.
- An IP address group can contain up to 640 IP addresses.
- A firewall instance can contain up to 30,000 IP addresses.
Adding Custom Address Groups
- Click in the upper left corner of the management console and select a region or project.
- In the navigation pane on the left, click and choose . The Dashboard page will be displayed.
- (Optional) Switch firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation pane, choose .
- Click the IP Address Groups tab. Click Add IP Address Group and configure parameters in the Add IP Address Group slide-out panel. For more information, see IP address group parameters.
Table 1 IP address group parameters Parameter
IP Address Group Name
Name of an IP address group.
It must meet the following requirements:- Only uppercase letters (A to Z), lowercase letters (a to z), numbers (0 to 9), and the following special characters are allowed: -_
- The length cannot exceed 255 characters.
Usage and application scenario of a rule
It must meet the following requirements:- Only letters (A to Z and a to z), numbers (0 to 9), spaces, and the following characters are allowed: -_
IP Addresses
Enter IP addresses and click Parse to add them to the IP address list.
The input can be:- A single IP address. Example: 192.168.10.5
- Address segment. Example: 192.168.2.0/24
- Consecutive IP addresses. Example: 192.168.0.2-192.168.0.10
- Multiple IP addresses. Use commas (,), semicolons (;), line breaks, tab characters, or spaces to separate them. Example: 192.168.1.0,192.168.1.0/24.
- Confirm the information and click OK. The IP address group is added.
Adding an IP Address to a Custom Address Group
- Click the IP Address Groups tab. Click the name of an IP address group. The IP Address Group Details slide-out panel is displayed.
- Click Add IP Address.
- To add IP addresses in batches, enter the IP addresses in the text box and click Parse.
The input can be:
- To add a single IP address, click Add, and enter the IP address and description.
Related Operations
- Exporting IP address groups: Click Export above the list.
- Batch deleting IP addresses: In the IP Address Group Details slide-out panel, select IP addresses and click Delete above the list.
Follow-up Operations
An IP address group takes effect only after it is set in a protection rule. For more information, see Adding Protection Rules to Block or Allow Traffic.
