Adjusting the Priority of a Protection Rule
When traffic hits a rule, the action of the rule will be performed, and CFW will not match the traffic against other protection rules. You are advised to set the priorities of the allowing rules to be higher than those of the blocking rules, and set the priorities of specific rules to be higher than those of general rules.
This section describes how to adjust the priorities of protection rules.
Priority
A larger value indicates a lower priority. The value 1 indicates the highest priority.
- Log in to the CFW console.
- Click
in the upper left corner of the management console and select a region or project.
- (Optional) Switch to another firewall instance. Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation pane on the left, choose > or .
- In the Operation column of a rule, click Configure Priority.
- Select Pin on top or Lower than the selected rule.
- If you select Pin on top, the policy is set to the highest priority.
- If you select , you need to select a group or rule. The policy priority will be lower than the selected rule.
- Click OK.
References
- For details about how to add a protection rule, see Configuring Protection Rules to Block or Allow Internet Border Traffic.
- For details about how to batch add blacklist or whitelist items, see Adding Blacklist or Whitelist Items to Block or Allow Traffic.
- Checking protection outcomes:
- Policy hits: For details about the protection overview, see Viewing Protection Information Using the Policy Assistant. For details about logs, see Access Control Logs.
- For details about the traffic trend and statistics, see Traffic Analysis. For details about traffic records, see Traffic Logs.
- For details about how to batch add protection policies, see Importing and Exporting Protection Policies.
