Creating a Call Center Instance
- An enterprise customer has applied for an access code.
For details, see Applying for Connecting to a Self-Owned Access Code.
- Before a tenant (call center instance) subscribes to resources, the tenant has contacted the O&M administrator of the CEC to determine whether the new tenant needs to be split. The O&M administrator of the CEC needs to manually modify the configuration.
- Log in to Huawei Cloud.
- Choose
Service List > Business Applications > Cognitive Engagement Center. - Choose Instance Management.
- Create a call center instance.
- Click Create Call Center Instance.
- Select an access code from the list. If multiple access codes are selected, specify an access code as the default outbound calling number.
An access code is used as a hotline number in a call center for taking customer calls or displayed as a calling number at the customer side.
If no access code is available, click Click here to apply for connecting to a self-owned access code. in the upper right corner to add a self-owned access code. For details, see Applying for Connecting to a Self-Owned Access Code.
- Click Next and set Instance Name.
- Click Next.
- Set agent specifications based on the following parameters:
- Current Region: Huawei Cloud site that supports the CEC function. If multiple sites are available, select the nearest site to reduce the network impact on agent access.
- Billing Mode: Select Pay-Per-Use.
- Specifications: Select the agent type as prompted. The options are Basic agent, Professional agent, and Advanced agent.
- Agent Quantity: Enter a value greater than or equal to 2. If more agent resources are required later, you can purchase them separately later.
- Click Next to check the billing items. Click Submit. The purchase success page is displayed.
After the subscription is complete, you can click Here to return to the CEC console.
- (Optional) Purchase a chatbot.
To use self-service, you need to purchase a chatbot.
- Choose
- Click corresponding to a call center instance and choose Purchase ChatBot.
- Set Purchase Type and Purchase Quantity, and click Next.
- Check the fee item details, read CEC Usage Agreement and Privacy Statement, select I have read and agree to CEC Usage Agreement and Privacy Statement, and click Submit. The subscription success page is displayed. Click Here to return to the ChatBot page.
- Choose
Follow-up Procedure
You can view the resources that you have subscribed to on the following pages:
- Resource Management > Access Code
- Resource Management > Agent
- Resource Management > IVR
- Resource Management > TTS&ASR
