User Level
Diagram Element
Parameter Description
  • Node Name: name of a node.
  • Description: details of a node.
  • User Level: Enter a non-negative integer or a string variable. The default value is 0, and the maximum value is 14. After calls are transferred to the manual service, the call from a high-level user is processed preferentially.
Condition Branch Description
Table 1 Condition branch description
Condition Branch
Usage
SYSERROR_INNER
ODFS internal error
Triggered when an unknown error occurs in the ODFS. If no option is selected, the flow goes to the exception handling flow.
fail
User level setting failure
Triggered when the call priority of a user fails to be set.
Using the Diagram Element
This diagram element is used when the priority (user level) of a call needs to be set and the call of a user with a higher priority is transferred to an agent first.
Click the diagram element or drag the diagram element to the canvas and set user level service parameters.
Typical Application Scenario
  1. Sign in to the AICC and choose Configuration Center > Chatbot Management > Flow Configuration.
  2. Configure an intelligent IVR flow.
    1. Choose Flow > Orchestration and click New to add a simple flow.
    2. Click + in the Flow Variable area. In the dialog box that is displayed, set the variable name and data type.
      Figure 1 Flow variables to be added
      Figure 2 Flow orchestration example (User Level diagram element)
      Figure 3 Flow orchestration example (Call Transfer diagram element)
    3. Save and publish the flow.
    4. Choose Intelligent Chatbot and bind the flow to a robot.
  3. Choose Configuration Center > Access Configuration > Called Party and add a called route. Set the IVR to the intelligent IVR added in 2.
  4. Set the current agent to the busy state, log in to the OpenEye using two softphone numbers to simulate two customers, and dial the access code added on the Called Party page at the same time. Answer the user level according to the voice prompt. You are advised to set different user levels for the two customers. Then, set the current agent to the idle state. If the customer of a higher level is connected to the agent first, the configuration is successful.
